N9k vPC with a standalone UCS C-series
sam wang
N9K1           N9K2
FEX121       FEX122
eth0--C240--eth1
Using vPCs go through FEX and using port-channel 200 to connect the independant Server (C240)
On N9K1 and On N9K2,   type  "Show mad address interface port-channel 200",   found the both sides only detected a same mac address from eth0 itself
I do know what wrong is .  Login to CIMC, there are no where can setup "Port-channel" for the both NICs (eth0,eth1)
Any idea?   Thank you for help !
sam wang
Kirk J
Greetings.
Your OS should be able to provide the teaming config for some variant of 802.3ad.
The CIMCs are not currently designed to configure port-channels/link aggregation.
Kirk..
