need help with nx-os show commands
gavinhans
what are nx-os show commands for following for ipv4 and ipv6:
1. show command interface vlan description
2. show command that with show interface subnet and its subnet mask.
3. show command to show all hsrp, vrrp VIPs with its subnets
Sergiu.Daniluk
N9K# show interface description
N9K# ! display IPv4/IPv6 + subnet
N9K# show ip interface vrf all
N9K# show ipv6 interface vrf all
N9K# ! display only IPv4/IPv6
N9K# show ip interface brief vrf all
N9K# show ipv6 interface brief vrf all
Note: if you have multiple VRFs on your switch, you can add "vrf all" at the end of the above commands to display info for all VRFs or "vrf X" for a specific VRF. If you work only in default VRF, you do not need to specify vrf option at the end of the command.
N9K# show hsrp
N9K# show hsrp brief
N9K# show vrrp
N9K# show vrrp detail
Note: hsrp/vrrp output will show display information for both ipv4/ipv6
Sergiu
what' s NX-OS command to see SVI description? show interface description command doesn't show SVI description.
N9K-1# show int description
Interface                Description
<snip> Vlan10 vlan 10
It should display the description of all L3 interfaces, including the SVIs.
Which platform and version you have?
Hello
conf t
feature hsrp
feature vrrp
feature interface-vlan
end
show hsrp brief
show vrrp detail
show interface brief
Kind Regards
Paul
