Showing results forĀ
Search instead forĀ
Did you mean:Ā
Nexus 1000v GUI
Bruce Summers
Alright folks,
just now messing with one of these...
My VM guy setup the VSM and i'm able to remote into the switch etc...however, I'm wanting to work the GUI magic and all i'm getting when entering the ip into my browser is what appears to be the directory structure
Index of /.
mode  links  bytes  last-changed  name
dr-x   3         120  Apr 25  2009  ./ drwx  13         260  Apr 22 21:16  ../ -r--   1          20  Apr 25  2009  bundle_id.txt dr-x   3         120  Apr 25  2009  cisco/ -rw-   1        1838  Apr 22 18:06  cisco_nexus_1000v_extension.xml -r--   1         229  Apr 22 18:07  index.xml
no nice GUI like the guide shows...
I'm running ver 4.0(4)SV1(1)
Helpppp!!!
thanks...
Bruce
abbharga
Level 4
Level 4
Hi Bruce,
The installer app is only avaiable with version SV1(2). With SV1(1) the only way to configure is via the console or the Telnet)
Abhinav
