Nexus 1000V, HP Flex-10 port speeds
jeff.mcluckie45
Afternoon,
Apologies if this is double posted.
We are currently  deploying a new VMWare Environment utilising an HP C Class Blade  Chassis, Virtual Connect 10GbE modules, BL680 blades with Flex10 NICs,  Nexus 1000V virtual switch and Nexus 5010 switches.
i.e.
Nexus  5010 -> HP VC 10GbE -> Flex10 NIC -> Nexus 1000V Virtual  Switch -> VMWare
In Virtual Connect the Flex 10 NICs are divided into two,  with a 1000Mbps and 9000Mbps interface on each. These show correctly in  VMWare.
We  have configured a port profile for the Nexus1000V Uplink to the LAN as  follows:
port-profile  type ethernet Trunk-Profile
  vmware port-group
  switchport mode  trunk
  switchport trunk allowed vlan 2-1200
  channel-group auto  mode on sub-group cdp
  no shutdown
  system vlan 1094,1196
   state enabled
This  comes up just fine, we can connect to VMs on Port Profiles created and  everything looks OK. However doing a show int brief shows all interfaces  and port channels up at 10Mbps. Initial testing on the VMs suggests the  networking is running above gig speeds so this may just be a display  bug but I cannot find any mention of this issue anywhere (HP, VMWare and  Cisco sites along with copious googling).
My options for forcing the port  speed are only 10,1000 and 10000. If I force to 1000 it drops then comes  back up at 10. If I try and force 10000 I get an error: Configuration  does not match the port capability.
Has anyone seen this before or know  what could cause it?
This  is what we get if we do a show int brief:
Port      VRF          Status IP Address                     Speed    MTU
mgmt0      --           up     10.153.94.21                   1000     1500
Ethernet       VLAN   Type Mode   Status  Reason                   Speed     Port
Interface        Ch #
Eth3/2         1      eth  trunk  up      none                         10(D) 1
Eth3/3         1      eth  trunk  up      none                         10(D) 1
Eth4/2         1      eth  trunk  up      none                         10(D) 2
Eth4/3         1      eth  trunk  up      none                         10(D) 2
Eth5/2         1      eth  trunk  up      none                         10(D) 3
Eth5/3         1      eth  trunk  up      none                         10(D) 3
Eth6/2         1      eth  trunk  up      none                         10(D) 4
Eth6/3         1      eth  trunk  up      none                         10(D) 4
Eth7/2         1      eth  trunk  up      none                         10(D) 5
Eth7/3         1      eth  trunk  up      none                         10(D) 5
Eth8/2         1      eth  trunk  up      none                         10(D) 6
Eth8/3         1      eth  trunk  up      none                         10(D) 6
Port-channel  VLAN  Type Mode   Status  Reason                    Speed  Protocol
Interface
Po1           1     eth  trunk  up      none                        a-10(D)  none
Po2           1     eth  trunk  up      none                        a-10(D)  none
Po3           1     eth  trunk  up      none                        a-10(D)  none
Po4           1     eth  trunk  up      none                        a-10(D)  none
Po5           1     eth  trunk  up      none                        a-10(D)  none
Po6           1     eth  trunk  up      none                        a-10(D)  none
Interface      VLAN   Type Mode   Status  Reason                   MTU
Veth1          60     virt access up      none                     1500
Veth2          60     virt access up      none                     1500
Veth3          2      virt access up      none                     1500
ctrl0      --           up     --                            1000     1500
mmehta
Hi Jeff,
This is a known issue with Nexus 1K and HP Flex-10 deployment. As you observed, this is only limited to
be a CLI display issue and there is no impact on the forwarding bandwidth or functionality. We are
looking to address it in a future release.
Munish.
