Nexus 1000v HA testing
jrivera00001
Im trying to test the following
SETUP;
-Two 5ks
- Two 2Ks
- one 2K has a dual home connection to each 5K
- the other 2K has a single home connection to the 5K
I have 3 connections from the 1K going to each 2K
Primary VSM is on ESX1
Standby VSM is on ESX2
the show mod on the 5K with fex 101 and 100 I see the following:
n1000v(200516105213107 Eth100/1/16     151     S I s       Nexus1000V    Eth4/3
n1000v(200516105213107 Eth100/1/17     151     S I s       Nexus1000V    Eth4/4
n1000v(200516105213107 Eth101/1/12     133     S I s       Nexus1000V    control0
n1000v(200516105213107 Eth101/1/13     147     S I s       Nexus1000V    Eth3/4
n1000v(200516105213107 Eth101/1/14     147     S I s       Nexus1000V    Eth3/3
on the 5k with only fex 100 i see the following:
n1000v(200516105213107 Eth100/1/16     140     S I s       Nexus1000V    Eth4/3
n1000v(200516105213107 Eth100/1/17     140     S I s       Nexus1000V    Eth4/4
My question is.. shouldnt I see Control0 on the both 5K
I dont see Ethe1001/1/15 when I do show cdp neighbor command.
I have verified that my trunks are confiugred correctly...
6 Replies 6
Robert Burns
There's only one primary (active) VSM at a time.  It's traffic is being pinned to FEX 101 at this time, which is only visible to the single N5K northbound.
I assume you're using "channel-group mode on mac-pinning" on your uplink port profile correct (of you N1K)?
Robert
Thanks for your response Robert
Yes I have "mac-pinning" configured ( see below )
port-profile type ethernet system-uplink
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 1-3967,4048-4093
  channel-group auto mode on mac-pinning
  no shutdown
  system vlan 580-581
  state enabled
So I should be able to shutdown my Primary VSM and see the Standby become active with my current setup?
Yes.  Issue a "system switchover" on the VSM or just kill the power on the primary to initiate a switchover.
Robert
Nice!
It worked
I now see the other control 0 come up
n1000v(200516105213107 Eth100/1/15     150     S I s       Nexus1000V    control0
n1000v(200516105213107 Eth100/1/16     148     S I s       Nexus1000V    Eth4/3
n1000v(200516105213107 Eth100/1/17     148     S I s       Nexus1000V    Eth4/4
n1000v(200516105213107 Eth101/1/13     148     S I s       Nexus1000V    Eth3/4
n1000v(200516105213107 Eth101/1/14     148     S I s       Nexus1000V    Eth3/3
and Module 1 on my 1000v is now the standby.
Mod  Ports  Module-Type                       Model               Status
1    0      Virtual Supervisor Module         Nexus1000V          ha-standby
2    0      Virtual Supervisor Module         Nexus1000V          active *
3    248    Virtual Ethernet Module           NA                  ok
4    248    Virtual Ethernet Module           NA                  ok
Thanks again Robert
Good stuff.   Another usefull command to keep in your back pocket is "show system redundancy status" - this will show you the sync status between your primary / standby VSM.  Always ensure it's fully in sync before doing any switchover testing or maintenance.
Robert
Thank you!
