nexus 1000v Installtion problem: Can't see the data port group in the vCenter
wagde
I'm trying to install and configure the Nexus1000v.4.0.4.SV1.2 according to the Getting Started guide n1000v_gsg.pdf.
I finished the installation and configuration "almost" successfully. Every thing worked fine, until I wanted to connect a VM vNic to the data20 port group. I noticed that the port group (data20) is not shown in the list of the port groups when I try to connect "Network Adapter 1" to it.
If I switch to the Network view. I see that my nexus configured and have a "data20" network. but It have 0 ports.
Can you please help?
Thanx
Wagde
9 Replies 9
abbharga
Level 4
Level 4
Hi Wagde,
Can you post / attach your configuration from the VSM for us to take a look at?
Abhinav
Hi Abhinav
Can you please tell me what commands should I run in the VSM to get the configuration?
I'm new to cisco nexus 1000v and I'm not familiar with the commands.
Thanx
Wagde
Output of the 'show run' command from the VSM will be fine..
Here you go:
n2# show run
version 4.0(4)SV1(2)
username admin password 5 $1$qHZap8N4$lF/1bHAcf37gElFTvv4Vu1  role network-admin
telnet server enable
ip domain-lookup
ip host n2 172.23.5.124
kernel core target 0.0.0.0
kernel core limit 1
system default switchport
vem 3
  host vmware id a2b92215-0d76-33a4-9df9-a81c8ebe0bdb
snmp-server user admin network-admin auth md5 0xe60b8856f288d60787ef398b8ea5ba28 priv 0xe60b8856f288d60787ef398b8ea5ba28 localizedke
y
snmp-server enable traps license
vrf context management
  ip route 0.0.0.0/0 172.23.5.4
switchname n2
vlan 1,20,260
vdc n2 id 1
  limit-resource vlan minimum 16 maximum 513
  limit-resource monitor-session minimum 0 maximum 64
  limit-resource vrf minimum 16 maximum 8192
  limit-resource port-channel minimum 0 maximum 256
  limit-resource u4route-mem minimum 32 maximum 80
  limit-resource u6route-mem minimum 16 maximum 48
port-profile type ethernet Unused_Or_Quarantine_Uplink
  description Port-group created for Nexus1000V internal usage. Do not use.
  vmware port-group
  shutdown
  state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
  vmware port-group
  shutdown
  state enabled
port-profile type ethernet data20
  description "Data"
  vmware port-group
  switchport mode access
  switchport access vlan 20
  no shutdown
  state enabled
port-profile type ethernet system-uplink
  description "System"
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 260
  no shutdown
  system vlan 260
  state enabled
port-profile type ethernet vm-uplink
  description "VM"
  vmware port-group
  switchport access vlan 260
  no shutdown
  state enabled
interface Ethernet3/3
  inherit port-profile system-uplink
interface mgmt0
  ip address 172.23.5.124/24
interface control0
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.0.4.SV1.2.bin sup-1
boot system bootflash:/nexus-1000v-mz.4.0.4.SV1.2.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.0.4.SV1.2.bin sup-2
boot system bootflash:/nexus-1000v-mz.4.0.4.SV1.2.bin sup-2
svs-domain
  domain id 153
  control vlan 260
  packet vlan 260
  svs mode L2
svs connection VC
  protocol vmware-vim
  remote ip address 194.29.47.70 port 80
  vmware dvs uuid "3e 30 00 50 9f d0 ff 32-d0 83 e2 e8 2f 06 a4 86" datacenter-name Wagde
  connect
Thanx
Wagde
Wagde,
Here is issue:
You have defined the 'data20' port-profile as an ethernet type profile, which will allow it be be used only for the uplink interface i.e to be applied on the physical ethernet interfaces. For a profile to be used for the VM interfaces it has to be of the type 'vethernet'.
Here is what you can do:
1) On the VSM issue the following command to delete the current data20 port-profile: 'no port-profile data20'
2) Define the port-profile again as: 'port-profile type vethernet data20' and then specify the rest of the configuration.
In the show run it would look something like this:
description "Data"
  vmware port-group
  no shutdown
  state enabled
Hope this helps!!!
./Abhinav
Great thanx
In the getting started guide it's ethernet and not vethernet :-)
I guss it should be fixed.
It's working fine now
Thanx
Wagde
Hi Wagde,
   Can you please specify which installation guide you are referring to and the section/chapter which has this ambiguity? We will get it corrected.
Vinutha
I'm referring to the n1000v_gsg.pdf document
Chapter 4
Page 19
In step 2: The data20 port profile type should be vethernet.
Thanx
Wagde
Thanks Wagde. The feedback has been submitted to the documentation team.
Vinutha
