"VEM SOURCE IP NOT CONFIGURED" for ERSPAN
jiangcaixia
I have some troubles when I configure ERSPAN feature on nexus1kv.
The environment i configured is:
1. There are two subnets: 10.112.* and 10.117.*
2. There is one nexus1kv in each subnet. Each nexus1kv is managed by one vc.(one vc in each subnet)
I want to export the packets from 10.112.* to the interface in 10.117.*. I new a port profile with "capability l3control" on nexus1kv in 10.112.* subnet. And go to vSphere Client and configure a VMKNIC for the ESX Host to make sure it points to this port profile as a new virtual adapter.
Then, I create a monitor session with source interface in 10.112.* and destination interface in 10.117.*. And I use netperf to create the packet flow for the interface in 10.112.*. But I can't get the duplicated packets from 10.112.* in 10.117.*.
So, I wonder whether there is some wrong configuration.
Can I use two vc to use ERSPAN?
Any idea?
Caixia
11 Replies 11
jiangcaixia
The host for nexus1kv is esx with service console.
The configuration of ERSPAN is:
Nexus1kv(config)# show monitor session 1
   session 1
description       : erspan
type              : erspan-source
state             : up
source intf       :
    rx            : Veth1
    tx            : Veth1
    both          : Veth1
source VLANs      :
    rx            :
    tx            :
    both          :
filter VLANs      : filter not specified
destination IP    : 10.117.4.49   // this is the ip for an ubuntu machine running wireshark, Can the destination IP be the virtual ethernet interface of Nexus1kv?
ERSPAN ID         : 55
ERSPAN TTL        : 64
ERSPAN IP Prec.   : 0
ERSPAN DSCP       : 0
ERSPAN MTU        : 1500
ERSPAN Header Type: 2
Nexus1kv(config)# show port-profile usage
Port Profile               Port        Adapter        Owner
system-uplink              Eth3/2      vmnic1         10.112.120.64
vm-pg                      Veth1       Net Adapter 1  testvds
vm-pg-erspan               Veth3       vmk0           Module 3
vm-pg2                     Veth2       Net Adapter 1  testvds-ubuntu
Nexus1kv# module vem 3 execute vemcmd show span
VEM SOURCE IP NOT CONFIGURED.
HW SSN ID            DST LTL/IP  ERSPAN ID  HDR VER
        0           10.117.4.49         55        2
On 10.112.120.64, "vmkping 10.117.4.49" is ok. Why the above command shows "VEM SOURCE IP NOT CONFIGURED"?
Any ideas? Thanks.
Caixia
Does anyone use ERSPAN before? Do you have any ideas?
Thanks in advance!
Caixia
Are you sure you set the IP address, Mask & GW for the VMKernel Interface assigned to the ERSPAN Port Profile?
Can you please past the config of
1. ERSPAN port profile.
2. VSM output of: module vem 3 execute vemcmd show span
3. From the CLI of your ESX host (VEM 3) esxcfg-vmknic -l
Here's what a typical ERSPAN (for SPAN of all uplink traffic) would look like:
nexus1kv(config)# monitor session 1 type erspan-source
nexus1kv(config-erspan-src)# source interface ethernet 3/3
nexus1kv(config-erspan-src)# destination ip 10.54.54.1
nexus1kv(config-erspan-src)# erspan-id 999
nexus1kv(config-erspan-src)# mtu 1000
nexus1kv(config-erspan-src)# no shut
nexus1kv(config)# show monitor session 1
   session 1
state             : up
source intf       :
    rx            : Eth3/3
    tx            : Eth3/3
    both          : Eth3/3
source VLANs      :
    rx            :
    tx            :
    both          :
destination IP    : 10.54.54.1
ERSPAN ID         : 999
ERSPAN TTL        : 64
ERSPAN IP Prec.   : 0
ERSPAN DSCP       : 0
ERSPAN MTU        : 1000
nexus1kv # module vem 3 execute vemcmd show span
VEM SOURCE IP: 10.54.54.10
        0                    47                 local
        1                   10.54.54.1          999
Robert
Hi Robert,
Thanks for your reply. I still get "VEM SOURCE IP NOT CONFIGURED". The following is my answer to your questions.
[Caixia] Yes, the ip address/mask/gw are assigned by DHCP. "esxcfg-vmknic -l" displays the result.
port-profile vm-pg-erspan
  description:
  type: vethernet
  status: enabled
  capability l3control: yes
  pinning control-vlan: -
  pinning packet-vlan: -
  system vlans: none
  port-group: vm-pg-erspan
  max ports: 32
  inherit:
  config attributes:
    switchport mode access
    no shutdown
  evaluated config attributes:
    no shutdown
  assigned interfaces:
    Vethernet3
        0           10.117.4.49         55        2
[root@localhost ~]# esxcfg-vmknic -l
Interface  Port Group/DVPort   IP Family IP Address                              Netmask         Broadcast       MAC Address       MTU     TSO MSS   Enabled Type
vmk0       224                 IPv4      10.112.120.104                          255.255.252.0   10.112.123.255  00:50:56:75:64:20 1500    65535     true    DHCP
4. esxcfg-vswitch -l
[root@localhost ~]# esxcfg-vswitch -l
Switch Name      Num Ports   Used Ports  Configured Ports  MTU     Uplinks
vSwitch0         128         6           128               1500    vmnic0
  PortGroup Name        VLAN ID  Used Ports  Uplinks
  Control               3000     1           vmnic0
  VM Network            0        1           vmnic0
  Packet                3002     1           vmnic0
  Service Console       0        1           vmnic0
DVS Name         Num Ports   Used Ports  Configured Ports  MTU     Uplinks
Nexus1kv         256         53          256               1500    vmnic1
  DVPort ID           In Use      Client
  160                 1           vmnic1
  161                 0
  162                 0
  163                 0
  164                 0
  165                 0
  166                 0
  167                 0
  168                 0
  169                 0
  170                 0
  171                 0
  172                 0
  173                 0
  174                 0
  175                 0
  176                 0
  177                 0
  178                 0
  179                 0
  180                 0
  181                 0
  182                 0
  183                 0
  184                 0
  185                 0
  186                 0
  187                 0
  188                 0
  189                 0
  190                 0
  191                 0
  224                 1           vmk0
  192                 1           testvds-ubuntu.eth0
  128                 1           testvds.eth0
  193                 0
Caixia
In your ERSPAN port-profile, there is no VLAN defined and hence there is no  system VLAN defined. This is a must for ERSPAN to work. Can you repeat the activity after you do that?
Praveen
Hi Praveen,
Do you mean that I should use "switchport access vlan vlan_id" and "system vlan vlan_id" in ERSPAN port-profile? Which num can I use for this vlan_id?
I want to explain my environment for nexus1kv: I only use two vlans for control vlan and packet vlan. So I don't know which vlan_id I should use for ERSPAN port-profile. And if I set a random num for this vlan_id, it will get the following error:
Nexus1kv(config-port-prof)# switchport access vlan 2
Nexus1kv(config-port-prof)# no shutdown
Nexus1kv(config-port-prof)# system vlan 2
ERROR: Some of the input vlans are not active.
All system vlans should be in the active state
Do you have any more suggestions?
Caixia
Hi Caixia,
              You are getting that error while configuring VLANs because you have not configured that VLAN in your N1K. You can configure any VLAN as your ERSPAN VLAN, the only prerequisite is that it must be globally routable from your upstream switch.
Let us say you are using VLAN 10 for your ERSPAN. Create the ERSPAN port-profile in access mode with VLAN 10. Make VLAN 10 as system vlan in that port-profile. Now VLAN 10 must be configured (made active) in both N1K and your upstream switch. Make sure that you allow the same in your uplink port-profile and the corresponding port in the upstream switch. Now create an L3 interface for this VLAN in your upstream switch and assign an ip address for it. Now make sure that this ip address is routable to your destination 10.117.* network. Now make sure that the vmknic ip address is in the same subnet as VLAN 10. Try end to end connectivity using a vmkping from your host. Now ERSPAN must work.
Praveen
Hi Praveen,
Thanks. I have some confusions about nexus1kv usage.
Because I have no physical switch to support nexus1kv. So I just use one host to configure nexus1kv. The vsm is in a vm on this host. And I think the control vlan and the packet vlan are necessary vlans for nexus1kv to make communications between vsm and vem. So, in my environment, vsm and vem are on the same machine, therefore, I think I don't need the support of the physical switch. I create the uplink port-profile to support system vlans(control vlan and packet vlan) and the regular port-profile without the vlan setting. So, in this case, I can make my data vm installed on these regular port-profile to connect to the outside network(with no vlan setting). And the vsm can still make communication to vem.
So, in this situation, how can I use ERSPAN?
The following are some my configurations:
port-profile system-uplink
  description:
  type: ethernet
  status: enabled
  capability l3control: no
  system vlans: 3000,3002
  port-group: system-uplink
  max ports: -
  inherit:
  config attributes:
    switchport mode trunk
    switchport trunk allowed vlan all
    no shutdown
    no shutdown
    Ethernet3/2
port-profile vm-pg
  description:
  type: vethernet
  status: enabled
  system vlans: none
  port-group: vm-pg
  max ports: 32
  inherit:
  config attributes:
    no shutdown
    no shutdown
    Vethernet1
I also have other questions about ERSPAN:
1. why ERSPAN port-profile needs a vlan_id. Does this vlan_id will be encapsulated into the ERSPAN packet?
2. What's the format of these ERSPAN packets if I can capture them on the destination port? Is the source mac address the vmknic ip address for ERSPAN port-profile? Is the destination mac address "10.117.4.49" which I set in ERSPAN monitor session?
Thanks in advance!
Caixia
Hi Caixia,
               I can see that in the upstream port-profile you have allowed all vlans and in the vethernet port-profile you have not specified any VLANs explicitly. That means that all your vethernet ports will be in VLAN 1 by default. I am wondering how you are using two different subnets an sending  packets between them without a routing device?
Now to make ERSPAN work you can try the following:
1. Declare VLAN 1 explicitly in N1K and make it active
2. In the ERSPAN port-profile explicitly mention VLAN 1 and make that VLAN as system VLAN
3. In the vmknic give an ip address in the 10.117* range instead of 10.112* range.
Now for your questions:
1. The VLAN id will not be encapsulated along with the ERSPAN packet, but we mention a VLAN because the ERSPAN module in N1K is designed n such a way that now it needs a VLAN and needs to be a system VLAN to work.
2. The ERSPAN packets will be normal IP packets which will be encapsulated using GRE and ERSPAN header. You can capture this at your destination and check. The source IP for this packet will be ip address of the vmknic of the host from which you are ERSPANing. The destination will be destination ip you have mentioned in the ERSPAN configuration.
Praveen
Thanks, Praveen.
I have captured the ERSPAN packets after I configured 1&2 to explicitly set vlan 1 in nexus1kv and ERSPAN port-profile. Thanks for your help. You are so nice!
I am interested in ERSPAN, so I want to ask a more question.
1. What does vlan 1 mean? The physical switch connected to my host is not set any vlan id, but it seems that it can allow packets from vlan 1 port-profile. The vm with vlan 1 port-profile can get the dhcp ip address.
Caixia
Hi Caixia,
    Its nice to know that you were able to get ERSPAN working.
Now about VLAN1, for any switching interface of any switch, when you do not configure any VLANs explicitly it will be a part of VLAN 1. VLAN1 is kind of a default VLAN that all switching devices will be part of. If you have a trunk interface then by default VLAN will be the native VLAN. That is in that interface VLAN 1 will not be tagged using the VLAN information. So now in your case since you just made the port as a switching interface (using switchport mode access), and did not specify any VLAN, that port by default became part of VLAN 1. This is not specific to ERSPAN. This is the general behaviour of any switching interface. Hope that helps.
Praveen
