06-14-2019 11:50 PM
I currently have a Nexus 3048TP which presents some concerning messages about the NVRam when it's booting. I've attached a full boot log with important parts highlighted/bolded.
Booting kickstart image: bootflash:/nxos.9.2.3.bin CardIndex = 11056 Image valid graphics_set_kernel_params enter: Installing klm_card_index done [ 4.681957] sd 1:0:0:0: [sda] No Caching mode page found [ 4.745347] sd 1:0:0:0: [sda] Assuming drive cache: write through [ 5.299394] sd 0:0:0:0: [sdb] No Caching mode page found [ 5.362782] sd 0:0:0:0: [sdb] Assuming drive cache: write through remounting root with size 2048M creating flash devices BOOT_DEV= sda INIT: version 2.88 booting Skipping ata_piix install for n3k. Unsquashing rootfs ... Total size needed in bootflash is 146936 check bootflash : OK Total size needed in bootflash is 35820 check bootflash : OK Removing libcrdcfgdata and linking libcrdcfgdata3nk Enabling 8250 serial driver spurious INTs workaround Installing isan procfs ... done. is_lxc: is_stby: suffix: Installing ftrace in non-lxc mode done Installing SSE module ... done. Creating SSE device node 247 ... done. Loading I2C driver ... done. Loading MEM scrub driver ... done. Installing CCTRL driver for card_type 30 without NEED_GEM ... done. 11.04: Interrupt throttling disabled. No cctrl irq detected. Loading IGB driver ... done. Checking for eUSB firmware upgrade.. eUSB firmware upgrade not required Checking all filesystems.Current boot disk sda3.. Installing SPROM driver ... IS_N3K done. Skipping installing default sprom values for N3k... Installing pfmsvcs module ...done. Installing nvram module ... done. Installing if_index module with port mode 6 ... done. Installing fcfwd stub Installing RNI lcnd ... done Installing LC netdev ... done Installing psdev module ... done. Installing veobc module ... done. Inserting mtdphysmap module...Inserting OBFL module ... done. Making OBFL character devices Mounting OBFL pstore for mtd Inserting kernel_services module ... done. Making kernel_services character devices cgroups initialized cat: /proc/isan/sw/nv_entry: No such file or directory exit code: 1 Starting OpenBSD Secure Shell server: sshd ... done. mkdir: cannot create directory '/lc': File exists Trim files after extracting TOR files ... tune2fs 1.42.9 (28-Dec-2013) Setting reserved blocks percentage to 0% (0 blocks) Starting portmap daemon... creating NFS state directory: done starting 8 nfsd kernel threads: done starting mountd: done starting statd: done Saving image for img-sync ... Loading system software Installing local RPMS Patch Repository Setup completed successfully Creating /dev/mcelog Starting mcelog daemon Removing dme lib Moving N3K specific syslog config file Loading a compact image INIT: Entering runlevel: 3 Running S93thirdparty-script... Populating conf files for hybrid sysmgr ... Removing bios-imgs and /lcimages Starting hybrid sysmgr ... Netbroker support IS present in the kernel. done Executing Prune clis. 2010 %$ VDC-1 %$ %%SYSLOG-6-SYSTEM_MSG: Invalid NVRAM Area. Reinit 2010 Jan 30 03:19:50 %$ VDC-1 %$ Jan 30 03:19:50 %KERN-2-SYSTEM_MSG: [ 59.758455] Initializing NVRAM Block 3 - kernel 2010 Jan 30 03:19:50 %$ VDC-1 %$ Jan 30 03:19:50 %KERN-2-SYSTEM_MSG: [ 59.758672] Initializing NVRAM Block 3 - kernel 2010 Jan 30 03:19:54 %$ VDC-1 %$ %USER-0-SYSTEM_MSG: Running compact image for this platform - pfm 2010 Jan 30 03:19:54 %$ VDC-1 %$ %PLATFORM-2-PS_OK: Power supply 2 ok (Serial number <removed>) 2010 Jan 30 03:19:54 %$ VDC-1 %$ %PLATFORM-2-PS_FANOK: Fan in Power supply 2 ok 2010 Jan 30 03:19:54 %$ VDC-1 %$ %PLATFORM-2-PS_ABSENT: Power supply 1 is absent/shutdown, ps-redundancy might be affected 2010 Jan 30 03:19:54 %$ VDC-1 %$ %PLATFORM-2-PS_RED_MODE_CHG: Power supply operational redundancy mode changed to non-redundant 2010 Jan 30 03:19:54 %$ VDC-1 %$ %PLATFORM-2-FANMOD_FAN_OK: Fan module 1 (Fan1(sys_fan1) fan) ok 2010 Jan 30 03:20:02 %$ VDC-1 %$ netstack: Registration with cli server complete
I had read that these messages may mean that the NVRam is faulty and that it should be replaced/RMA'd. I've already tried running "write erase", but these errors still appear after a reload.
Apart from these messages, everything appears to be working normally (config and OS images persists through reboots, no errors while running nxos, etc.)
Is this something I should be concerned about? Are there any additional tests I can perform to determine whether this is a hardware issue?
06-21-2019 07:40 AM
