Nexus 3048
beta_admin66
Hello together,
I'm trying to load the Cisco Nexus Switch 3048 with the system image, but there are these error messages:
switch(boot)# load bootflash:nxos.7.0.3.I4.8a.bin
/etc/rc.d/rcS.d/S99load-isan: line 50: [: ff: integer expression expected
/etc/rc.d/rcS.d/S99load-isan: line 58: [: ff: integer expression expected
Loading System Software Tue Nov 9 12:47:05 UTC 2010
INIT: Switching to runlevel: 3
INIT: Sending processes the TERM signal
INIT: (boot)#
Mounting other filesystems: [ OK ]
INIT: c
INIT: cannot execute "/isan/bin/libvirtd.sh"
INIT: cannot execute "/isan/bin/sysmgr_spawn"
INIT: Id "libv" respawning too fast: disabled for 5 minutes
INIT: Id "sm" respawning too fast: disabled for 5 minutes
ERROR: ld.so: object '/isan/lib/libnxoscustom.so' from LD_PRELOAD cannot be preloaded: ignored.
User Access Verification
(none) login: xxx
Password:
I've now learned that you can copy the BIOS into the bootflash. Where can I download the BIOS nxos-n3kbios.bin and copy it to the bootflash? I couldn't find this on the Cisco website.
The one on this switch is BioS BIOS v.1.2.0
Can you help me?
Thank you very much.
Christopher Hart
Hello!
Nexus 3048 switches can be very picky about NX-OS upgrade/downgrade paths. I see you're trying to load NX-OS software release 7.0(3)I4(8a) - do you know what NX-OS software release this switch was previously running?
Thank you!
-Christopher
beta_admin66
kickstart-image: n3000-uk9-kickstart.6.0.2.U6.10.bin
system-image: nxos.7.0.3.I4.8a.bin
Hello!
It sounds like you are booting into the NX-OS 6.0(2)U6(10) kickstart image, then attempting to load the NX-OS 7.0(3)I4(8a) unified binary image. This procedure is not supported - NX-OS software releases that utilize kickstart and system images must always have matching kickstart and system images. You will need to load into the NX-OS 6.0(2)U6(10) kickstart image, then load into the NX-OS 6.0(2)U6(10) system image, then upgrade to the unified NX-OS 7.0(3)I4(8a) binary image using the install all command.
If you do not have the NX-OS 6.0(2)U6(10) system image on the bootflash, you should be able to copy the file via TFTP from boot loader.
Thank you!
-Christopher
