Nexus 3548-X / 24 ports base license
sharlino
Hello!
We have a Nexus C3548P-10GX.
sh license usage
Feature Ins Lic Status Expiry Date Comments
Count
24P_LIC_PKG Yes - Unused Never -
24P_UPG_PKG No - Unused -
LAN_BASE_SERVICES_PKG Yes - In use Never -
ALGO_BOOST_SERVICES_PKG No - Unused -
LAN1K9_ENT_SERVICES_PKG No - Unused -
LAN_ENTERPRISE_SERVICES_PKG No - Unused -
From a technical point of view, can we use all the 48 ports ? If yes, will it run with any limitations, for instance, trial period, limited bandwidth/speed, PPS or similar ?
nazimkha
As far as I know, Nexus 3000 series switches have honor based licenses i.e you can use them without installing and they will never expire but in order to be compliant with Cisco you need to purchase and install them on the switch.
The 24 port upgrade license maybe also honor based
