Nexus 3K IP SLA Issue
When I tried to enable SLA  feature,  i faced this Problem
Core-1(config)# feature sla sender
Stub Library libsla_s_showcli.so could not be opened
* libsla_s_showcli.so: cannot open shared object file: No such file or directory *
the image running is n3000-uk9.6.0.2.U3.7.bin
Dawei
This is due to the sla feature not supported on this old release on N3K platform. You can try to upgrade to the 7.0.3x and test it again if you still want to use sla feature.
 https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/IP_SLA/7x/b_Cisco_Nexus_3000_Series_NX-OS_IP_SLAs_Configuration_Guide_7x/b_Cisco_Nexus_3000_Series_NX-OS_IP_SLAs_Configuration_Guide_7x_chapter_01.html
Feature
Description
Changed in Release
IP SLA support
Initial support
NX-OS 7.0(3)I2(1)
Recommended Cisco NX-OS Releases for Cisco Nexus 3000, 3100, 3200, 3400-S, 3500, and 3600 Series Switches
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/recommended_release/b_Minimum_and_Recommended_Cisco_NX-OS_Releases_for_Cisco_Nexus_3000_Series_Switches.html
