Nexus 5k
 Is criss-cross connection is possible between conventional N2k and N5k, if yes which nexus OS version supports?
nazimkha
Level 4
Level 4
I think you mean dual-homed vPC between Nexus 5K and Nexus 2K ? something as per the below link
https://www.cisco.com/c/en/us/support/docs/switches/nexus-2000-series-fabric-extenders/200363-nexus-2000-fabric-extenders-supported-un.html#anc9
Yes, Thanks for the help. I was looking of the IOS version and your document has that
