11-30-2021 12:58 AM
I'm trying to do a xconnect between two 10G ports on two different Nexus 9396PX switches, however, unable to do it in spite of following this document for guidelines: https://www.cisco.com/c/en/us/support/docs/switches/nexus-9000-series-switches/213958-nexus-9000-vxlan-xconnect-configuration.html
So far I have completed the steps for enabling and configuring the ngoam feature as recommended on the above link, however I'm struggling to complete the xconnect peering due to the following issue:
# show ngoam xconnect session 3092 Vlan ID: 3092 Peer IP: 10.128.164.139 VNI : 9003092 State: Heartbeat loss, Last state update: 11/29/2021 17:21:00.321 Local interface: Eth1/16 State: ERR Local vpc interface Unknown State: DOWN Remote interface: Unknown State: DOWN Remote vpc interface: Unknown State: DOWN
The heartbeat loss is also seen on the peer switch, however all other diagnostic effort don't seem to show any issue evidence:
# show bgp l2vpn evpn BGP routing table information for VRF default, address family L2VPN EVPN BGP table version is 5, Local Router ID is 10.128.44.182 Status: s-suppressed, x-deleted, S-stale, d-dampened, h-history, *-valid, >-best Path type: i-internal, e-external, c-confed, l-local, a-aggregate, r-redist, I-injected Origin codes: i - IGP, e - EGP, ? - incomplete, | - multipath, & - backup, 2 - best2 Network Next Hop Metric LocPrf Weight Path Route Distinguisher: 10.128.44.182:35859 (L2VNI 9003092) *>l[3]:[0]:[32]:[10.128.144.182]/88 10.128.144.182 100 32768 i *>i[3]:[0]:[32]:[10.128.164.139]/88 10.128.164.139 100 0 i Route Distinguisher: 10.128.64.139:35859 * i[3]:[0]:[32]:[10.128.164.139]/88 10.128.164.139 100 0 i *>i 10.128.164.139 100 0 i # show nve peers Interface Peer-IP State LearnType Uptime Router-Mac --------- -------------------------------------- ----- --------- -------- ----------------- nve1 10.128.164.139 Up CP 17:32:39 n/a # show nve vni 9003092 Codes: CP - Control Plane DP - Data Plane UC - Unconfigured SA - Suppress ARP SU - Suppress Unknown Unicast Xconn - Crossconnect MS-IR - Multisite Ingress Replication Interface VNI Multicast-group State Mode Type [BD/VRF] Flags --------- -------- ----------------- ----- ---- ------------------ ----- nve1 9003092 225.30.9.2 Up CP L2 [3092] Xconn # show ip bgp all summary BGP summary information for VRF default, address family IPv4 Unicast BGP summary information for VRF default, address family IPv6 Unicast BGP summary information for VRF default, address family L2VPN EVPN BGP router identifier 10.128.44.182, local AS number xxxxxxx BGP table version is 5, L2VPN EVPN config peers 2, capable peers 2 3 network entries and 4 paths using 732 bytes of memory BGP attribute entries [3/516], BGP AS path entries [0/0] BGP community entries [0/0], BGP clusterlist entries [2/8] Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd 10.128.2.183 4 xxxxxxx 14037 1058 5 0 0 17:33:31 1 10.128.2.184 4 xxxxxxx 14033 1058 5 0 0 17:33:29 1 # show running-config bgp version 9.3(8) Bios:version 07.69 feature bgp router bgp xxxxxxx router-id 10.128.44.182 address-family l2vpn evpn maximum-paths 64 maximum-paths ibgp 64 neighbor 10.128.2.183 remote-as xxxxxxx description SPINEswitch1 update-source loopback0 address-family l2vpn evpn send-community send-community extended neighbor 10.128.2.184 remote-as xxxxxxx description SPINEswitch2 update-source loopback0 address-family l2vpn evpn send-community send-community extended evpn vni 9003092 l2 rd auto route-target import auto route-target export auto
PIM-RP has been also configured all along the path, however, not sure about the following:
- the 9396px is not on the xconnect supported list, however, the 9372px is, I thought they are almost identical by means of supported features, were I wrong in assuming this?
- do I need to enable ngoam all along the spine paths between all switches, I didn't do it yet, the spines are BGP RR, PIM and OSPF routers so far?
- last but not least, is there any tcam carving necessary in order to make it work?
Any ideas on how to make it work will be appreciated greatly.
Thank you.
Solved! Go to Solution.
06-03-2022 11:32 AM - edited 06-03-2022 11:33 AM
It appears I'm talking to myself here
Let me share the final outcome -> the case is now resolved and the xconnect works as resolved <-
There is a requirement to do tcam carving on vxlan-p2p to 256 or more, nothing of this kind is documented anywhere however I found it in my tryouts.
Example setting:
hardware access-list tcam region vacl 0 hardware access-list tcam region racl 0 hardware access-list tcam region span 0 hardware access-list tcam region arp-ether 256 double-wide hardware access-list tcam region vxlan-p2p 256
Applies to 9372 and 9396 /confirmed working with the above carving/ and also 9364C /confirmed working without any tcam carving at all/.
04-02-2022 02:23 AM - edited 04-02-2022 02:25 AM
I have managed to progress this a bit, I feel I'm closer to the expected end result however there's no communication yet over the xconnect...
I did some tcam carving as follows:
hardware access-list tcam region ifacl 256 hardware access-list tcam region vacl 0 hardware access-list tcam region racl 256 hardware access-list tcam region e-racl 0 hardware access-list tcam region span 0 hardware access-list tcam region arp-ether 256 double-wide
This brought an end result where the xconnect session shows as up and running on both switches in the lab:
States: LD = Local interface down, RD = Remote interface Down HB = Heartbeat lost, DB = Database/Routes not present * - Showing Vpc-peer interface info Vlan Peer-ip/vni XC-State Local-if/State Rmt-if/State =============================================================================== 309210.128.144.182 / 9003092 Active Eth1/37 / UP Eth1/37 / UP
However no transport over the line. I'm pushing some multicast traffic to the Eth1/37.
interface Ethernet1/37
switchport mode dot1q-tunnel
switchport access vlan 3092
spanning-tree bpdufilter enable
mtu 9216
Ethernet1/37 is up
30 seconds input rate 1538270328 bits/sec, 140794 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
However nothing is going out through the (only) underlay port I have at the moment:
Ethernet1/28 is up 30 seconds input rate 30488 bits/sec, 41 packets/sec 30 seconds output rate 24976 bits/sec, 41 packets/sec
Here's a list of type 3 routes exchanged:
# show bgp l2vpn evpn route-type 3 BGP routing table information for VRF default, address family L2VPN EVPN Route Distinguisher: 10.128.44.182:35859 BGP routing table entry for [3]:[0]:[32]:[10.128.144.182]/88, version 13 Paths: (2 available, best #1) Flags: (0x000002) (high32 00000000) on xmit-list, is not in l2rib/evpn, is not in HW Multipath: eBGP iBGP Advertised path-id 1 Path type: internal, path is valid, is best path, no labeled nexthop Imported to 1 destination(s) Imported paths list: L2-9003092 AS-Path: NONE, path sourced internal to AS 10.128.144.182 (metric 9) from 10.128.2.183 (10.128.2.183) Origin IGP, MED not set, localpref 100, weight 0 Extcommunity: RT:65000:9003092 ENCAP:8 Originator: 10.128.44.182 Cluster list: 10.128.2.183 PMSI Tunnel Attribute: flags: 0x00, Tunnel type: Ingress Replication Label: 9003092, Tunnel Id: 10.128.144.182 Path type: internal, path is valid, not best reason: Neighbor Address, no labeled nexthop AS-Path: NONE, path sourced internal to AS 10.128.144.182 (metric 9) from 10.128.2.184 (10.128.2.184) Origin IGP, MED not set, localpref 100, weight 0 Extcommunity: RT:65000:9003092 ENCAP:8 Originator: 10.128.44.182 Cluster list: 10.128.2.184 PMSI Tunnel Attribute: flags: 0x00, Tunnel type: Ingress Replication Label: 9003092, Tunnel Id: 10.128.144.182 Path-id 1 not advertised to any peer Route Distinguisher: 10.128.54.168:35859 (L2VNI 9003092) BGP routing table entry for [3]:[0]:[32]:[10.128.144.182]/88, version 14 Paths: (1 available, best #1) Flags: (0x000012) (high32 00000000) on xmit-list, is in l2rib/evpn, is not in HW Multipath: eBGP iBGP Advertised path-id 1 Path type: internal, path is valid, is best path, no labeled nexthop Imported from 10.128.44.182:35859:[3]:[0]:[32]:[10.128.144.182]/88 AS-Path: NONE, path sourced internal to AS 10.128.144.182 (metric 9) from 10.128.2.183 (10.128.2.183) Origin IGP, MED not set, localpref 100, weight 0 Extcommunity: RT:65000:9003092 ENCAP:8 Originator: 10.128.44.182 Cluster list: 10.128.2.183 PMSI Tunnel Attribute: flags: 0x00, Tunnel type: Ingress Replication Label: 9003092, Tunnel Id: 10.128.144.182 Path-id 1 not advertised to any peer BGP routing table entry for [3]:[0]:[32]:[10.128.154.168]/88, version 2 Paths: (1 available, best #1) Flags: (0x000002) (high32 00000000) on xmit-list, is not in l2rib/evpn Multipath: eBGP iBGP Advertised path-id 1 Path type: local, path is valid, is best path, no labeled nexthop AS-Path: NONE, path locally originated 10.128.154.168 (metric 0) from 0.0.0.0 (10.128.54.168) Origin IGP, MED not set, localpref 100, weight 32768 Extcommunity: RT:65000:9003092 ENCAP:8 PMSI Tunnel Attribute: flags: 0x00, Tunnel type: Ingress Replication Label: 9003092, Tunnel Id: 10.128.154.168 Path-id 1 advertised to peers: 10.128.2.183 10.128.2.184
Switch 2:
# show bgp l2vpn evpn route-type 3 BGP routing table information for VRF default, address family L2VPN EVPN Route Distinguisher: 10.128.44.182:35859 (L2VNI 9003092) BGP routing table entry for [3]:[0]:[32]:[10.128.144.182]/88, version 2 Paths: (1 available, best #1) Flags: (0x000002) (high32 00000000) on xmit-list, is not in l2rib/evpn Multipath: eBGP iBGP Advertised path-id 1 Path type: local, path is valid, is best path, no labeled nexthop AS-Path: NONE, path locally originated 10.128.144.182 (metric 0) from 0.0.0.0 (10.128.44.182) Origin IGP, MED not set, localpref 100, weight 32768 Extcommunity: RT:65000:9003092 ENCAP:8 PMSI Tunnel Attribute: flags: 0x00, Tunnel type: Ingress Replication Label: 9003092, Tunnel Id: 10.128.144.182 Path-id 1 advertised to peers: 10.128.2.183 10.128.2.184 BGP routing table entry for [3]:[0]:[32]:[10.128.154.168]/88, version 376 Paths: (1 available, best #1) Flags: (0x000012) (high32 00000000) on xmit-list, is in l2rib/evpn, is not in HW Multipath: eBGP iBGP Advertised path-id 1 Path type: internal, path is valid, is best path, no labeled nexthop Imported from 10.128.54.168:35859:[3]:[0]:[32]:[10.128.154.168]/88 AS-Path: NONE, path sourced internal to AS 10.128.154.168 (metric 13) from 10.128.2.183 (10.128.2.183) Origin IGP, MED not set, localpref 100, weight 0 Extcommunity: RT:65000:9003092 ENCAP:8 Originator: 10.128.54.168 Cluster list: 10.128.2.183 PMSI Tunnel Attribute: flags: 0x00, Tunnel type: Ingress Replication Label: 9003092, Tunnel Id: 10.128.154.168 Path-id 1 not advertised to any peer Route Distinguisher: 10.128.54.168:35859 BGP routing table entry for [3]:[0]:[32]:[10.128.154.168]/88, version 195 Paths: (2 available, best #1) Flags: (0x000002) (high32 00000000) on xmit-list, is not in l2rib/evpn, is not in HW Multipath: eBGP iBGP Advertised path-id 1 Path type: internal, path is valid, is best path, no labeled nexthop Imported to 1 destination(s) Imported paths list: L2-9003092 AS-Path: NONE, path sourced internal to AS 10.128.154.168 (metric 13) from 10.128.2.183 (10.128.2.183) Origin IGP, MED not set, localpref 100, weight 0 Extcommunity: RT:65000:9003092 ENCAP:8 Originator: 10.128.54.168 Cluster list: 10.128.2.183 PMSI Tunnel Attribute: flags: 0x00, Tunnel type: Ingress Replication Label: 9003092, Tunnel Id: 10.128.154.168 Path type: internal, path is valid, not best reason: Neighbor Address, no labeled nexthop AS-Path: NONE, path sourced internal to AS 10.128.154.168 (metric 13) from 10.128.2.184 (10.128.2.184) Origin IGP, MED not set, localpref 100, weight 0 Extcommunity: RT:65000:9003092 ENCAP:8 Originator: 10.128.54.168 Cluster list: 10.128.2.184 PMSI Tunnel Attribute: flags: 0x00, Tunnel type: Ingress Replication Label: 9003092, Tunnel Id: 10.128.154.168 Path-id 1 not advertised to any peer
Any ideas on how to continue the troubleshooting efforts will be appreciated.
Thank you everybody for the time spent on this.
05-27-2022 12:04 AM
I just had the opportunity to test the same configuration on a 9364C switch and it worked right away.
However, 9372 and 9396 continue to behave as if there's absolutely no traffic over the xconnect circuit. The ngoam session is established and all ports are UP on both sides however interface counters remain zero.
I think I'm missing some tcam carving in addition to the arp-ether 256 double-wide. I'm continuing to spend a lot of time in trying out lots of stuff however no luck so far.
Example setting:
04-14-2023 03:36 AM
Hello everyone
I allow myself to post this topic because I have exactly the same problem, even by applying the hardware commands.
We have C9372PX in 9.3.11.
I don't know how to debug?
Vlan ID: 1103
Peer IP: 10.2.4.10 VNI: 1103
Last state update: 04/14/2023 12:26:46.932
Local interface: Unknown State: ERR
04-14-2023 04:00 AM
Dear friend,
it seems that your gear is not even reporting what the local interface is. Hence I suspect that you might not have configured the dot1q access vlan on the interface and the VLAN does not have xconnect enabled on it.
vlan 1103
vn-segment xxxxxx
xconnect
Please double check that, thank you.
04-14-2023 04:38 AM
Hello
I have this in both side :
vlan 1103
vn-segment 1103
xconnect
interface nve1
member vni 1103
evpn
vni 1103 l2
rd 65500:1103
interface Ethernet1/9
switchport access vlan 1103
