03-06-2023 09:24 AM
We have the scenario (have a look at the Visio) that we need a vPC over all our 4 Nexus Switches in two different DC's to get this virtual loadbalancer working in a active active with loadbalancer 1 and 2.
Our current configuration is a vPC in both DC's and between the DC's is a Port-Channel with two links.
Two options come to my mind:
1. vPC over all 4 Nexus Switches
Is it possible to build a vPC over 4 Nexus Switches? I found a Best Practice sheet from Cisco in which i read that a vPC can only be configured with max 2 Nexus Nodes. Can anyone confirm this?
2. Break Port-Channel 30, create a vPC between Core1 / Core3 and connect Loadbalander1 only with Core1 and Loadbalancer2 only with Core3
For this I need the option to configure multiple vPC's on one Nexus. Is this possible or can I configure just one vPC on one Nexus?
Maybe someone has another idea how we can solve this issue.
Thanks!
Solved! Go to Solution.
03-08-2023 05:07 AM
Hello @Florian Henghuber
vPC can only be configured between a maximum of two Nexus switches. This is because vPC is a technology that enables you to configure a Port-Channel between two switches and treats them as a single logical entity, which provides redundancy and load balancing benefits.
It's not possible to configure multiple vPC domains on the same Nexus device. A vPC domain is a logical entity that represents a set of Nexus switches that are configured with the same vPC domain ID. The purpose of a vPC domain is to ensure that the same vPC domain ID is used across all switches in the vPC domain to avoid potential configuration issues or inconsistencies.
In general, a vPC domain is created on a pair of Nexus switches that are configured with a vPC peer link. The vPC peer link is used to synchronize control plane information between the 2 switches and provides a loop-free path for forwarding traffic across the vPC domain. Each vPC domain can have only 1 peer link, which connects the two switches that are part of the vPC domain.
03-08-2023 05:07 AM
03-08-2023 05:35 AM
Thanks a lot for your detailed answer.
