01-06-2020 07:23 AM
Hello!
N00b question I'm sure.
I have a pair of Nexus 93180YC-EX running 9.2(2) in VPC mode.
I'm trying to get a basic VXLAN EVPN between them. This is a working "Classic" environment, only have the two 9ks, no other swithes. This is a secondary DC, so I'm starting there... I have a pair of 7706s at my primary DC that I'll look to expand this to as well later on. Overall goal is to be able to have a couple of the same VLANs at secondary DC.
Anyway, VPC is running in classic is fine.
I'm trying to follow this configuration guide:
It seems none of the "evpn" config options are available to me.
I had to enabled 'feature fabric forwarding' to get the fabric commands that are referenced, but asside from that, I'm trying to follow it pretty closely.
Here's an example of what's missing:
Config guide says:
Configure the tenant VRF.
Step 1 | vrf context vxlan | Configure the VRF. | ||
Step 2 | vni number | Specify VNI. | ||
Step 3 | rd auto | Specify VRF RD (route distinguisher). | ||
Step 4 | address-family ipv4 unicast | Configure address family for IPv4. | ||
Step 5 | route-target both auto |
Step 6 | route-target both auto evpn |
My Results:
DR-N9k-2(config)# vrf context VXLANTEST
DR-N9k-2(config-vrf)# vni 5076
DR-N9k-2(config-vrf)# rd auto
DR-N9k-2(config-vrf)# address-family ipv4 unicast
DR-N9k-2(config-vrf-af-ipv4)# route-target both auto
DR-N9k-2(config-vrf-af-ipv4)# route-target both auto evpn
% Invalid command at '^' marker.
DR-N9k-2(config-vrf-af-ipv4)# route-target both auto ?
<CR>
Another Example:
Step 1 | router bgp number | Configure BGP. | ||
Step 2 | router-id address | Specify router address. | ||
Step 3 | neighbor address remote-as number | Define MPBGP neighbors. Under each neighbor define L2VPN EVPN. | ||
Step 4 | address-family ipv4 unicast | Configure the address family for IPv4. | ||
Step 5 | address-family l2vpn evpn | Configure address family Layer 2 VPN EVPN under the BGP neighbor.
Step 6 | (Optional) Allowas-in | (Optional) Allows duplicate autonomous system (AS) numbers in the AS path. Configure this parameter on the leaf for eBGP when all leafs are using the same AS, but the spines have a different AS than leafs. | ||
Step 7 | send-community extended | Configures community for BGP neighbors. | ||
Step 8 | vrf vrf-name | Specify VRF. | ||
Step 9 | address-family ipv4 unicast | Configure the address family for IPv4. | ||
Step 10 | advertise l2vpn evpn | Enable advertising EVPN routes.
My Switch outputs:
DR-N9k-2(config-vrf)# router bgp 65107
DR-N9k-2(config-router)# neighbor 76.76.76.76 remote-as 65107 !This is just a loopback on the other 9k in VPC pair.
DR-N9k-2(config-router-neighbor)# address-family ipv4 unicast
DR-N9k-2(config-router-neighbor-af)# address-family l2vpn evpn
DR-N9k-2(config-router-neighbor-af)# address-family l2vpn ?
DR-N9k-2(config-router-neighbor-af)# address-family ?
*** No matching command found in current mode, matching in (config-router-neighbor) mode ***
ipv4 Configure IPv4 address-family
ipv6 Configure IPv6 address-family
l2vpn Configure L2VPN address-family
link-state Configure link-state address-family
vpnv4 Configure IPv4 VPN address-family
vpnv6 Configure IPv6 VPN address-family
% Incomplete command at '^' marker.
Is there something I'm missing here? A license? A feature?
License on both 9k:
DR-N9k-2(config-router-neighbor-af)# show license
license_<snip>_25.lic:
SERVER this_host ANY
VENDOR cisco
INCREMENT LAN_ENTERPRISE_SERVICES_PKG cisco 1.0 permanent uncounted \
01-08-2020 04:57 PM
Do you have the commands shown below configured?
# Feature nv overlay
# nv overlay evpn
