Nexus C3232C code upgrade issue Pre-upgrade check failed. Return code 0x404F0003)
maso Kamali
Having a hard time upgrading the code on this N3K-C3232C, i'd appreciate any advice on this. I am not sure if I am using the incorrect file or if there is a pre-upgrade step I am missing. below are the details from an upgrade attempt.
switch# install all nxos bootflash:nxos.7.0.3.I7.6.bin
Installer will perform compatibility check first. Please wait.
uri is: /nxos.7.0.3.I7.6.bin
Installer is forced disruptive
"Failed to process nxos image".
Pre-upgrade check failed. Return code 0x404F0003 (SRG file not present/cannot be opened).
kevinchan
Maso,
     I saw the same thing when I was trying upgrade from 7.0.3(IX1.2) to 7.0(3)I7(6).
     Upgrade to 7.0(3)I7(3) first, then upgrade to 7.0(3)I7(6).
give it a try.
Kevin
5 Replies 5
deepakbalan
Can you check the MD5 value is same as the value mentioned in the software download page.
Sent from Yahoo Mail on Android
The file is ok, md5 value matches.
kevinchan
Maso,
give it a try.
Kevin
Thanks Kevin, i'll try it out and follow up.
Kevin, that did the trick. thank you
