nexus switch: flash removable
gavinhans
Level 2
Level 2
is built in (in switch or sup) flash removable on nexus switches?
Sergiu.Daniluk
If I am not mistaking, Nexus 7000 is the only one on which you can replace the compact flash. On the other Nexus platforms you cannot (it's soldered on the motherboard).
Stay safe,
Sergiu
Thanks. is system memory (dram, nvram) removable on all nexus?
N7K and N9K yes, not sure about 3k.
Sergiu
