10-07-2014 02:36 AM
I config N1kV in svs mode l3 using interface control0 and run in vlan 1, and application data vlan in vlan 11, when i config ERSPAN , source on VETH7 and destination is 192.168.1.1.12 , i create port-profile ERSPAN, and two vmkernel port on two ESXi.
but when i type commant:
port-profile ERSPAN
system vlan 11
two VEM left VSM, but same config in SVS mode l2 is ok,
what's problem, I think VLAN 11 is a application/data vlan ,not affect VSM and VEM communication.
Thank you!
Tom
port-channel port-profile
Nexus1000V(config)# port-profile ERSPAN
Nexus1000V(config-port-prof)# system vlan 11
Nexus1000V(config-port-prof)# 2014 Oct 7 09:35:18 Nexus1000V %PLATFORM-2-PFM_VEM_REMOVE_NO_HB: Removing VEM 3 (heartbeats lost)
2014 Oct 7 09:35:18 Nexus1000V %PLATFORM-2-PFM_VEM_REMOVE_NO_HB: Removing VEM 4 (heartbeats lost)
2014 Oct 7 09:35:18 Nexus1000V %PLATFORM-2-MOD_REMOVE: Module 3 removed (Serial number )
2014 Oct 7 09:35:18 Nexus1000V %PLATFORM-2-MOD_REMOVE: Module 4 removed (Serial number )
Nexus1000V# show running-config
version 4.0(4)SV1(3a)
username admin password 5 $1$.aGFgZtH$qSe2G0lAB7JGmKzfLDwL50 role network-admin
no password strength-check
ip domain-lookup
ip host Nexus1000V 10.2.11.5
kernel core target 0.0.0.0
kernel core limit 1
system default switchport
vem 3
host vmware id 420b5865-b9db-e6dc-0f02-99b3642c5d35
vem 4
host vmware id 420bbf4d-7a3b-e73e-125a-72a503d2d022
snmp-server user admin network-admin auth md5 0xe90e1fbf4aa6dd0ccde9bb8f2db21c3f
priv 0xe90e1fbf4aa6dd0ccde9bb8f2db21c3f localizedkey
snmp-server enable traps license
vrf context management
ip domain-name vpod.local
ip name-server 10.2.11.1
ip route 0.0.0.0/0 10.2.11.1
hostname Nexus1000V
vlan 1,10-12,111
vdc Nexus1000V id 1
limit-resource vlan minimum 16 maximum 513
limit-resource monitor-session minimum 0 maximum 64
limit-resource vrf minimum 16 maximum 8192
limit-resource port-channel minimum 0 maximum 256
limit-resource u4route-mem minimum 32 maximum 80
limit-resource u6route-mem minimum 16 maximum 48
port-profile type vethernet ERSPAN
capability l3control
vmware port-group
switchport mode access
switchport access vlan 11
no shutdown
state enabled
port-profile type vethernet L3-control
vmware port-group
no shutdown
system vlan 1
state enabled
port-profile type ethernet Unused_Or_Quarantine_Uplink
description Port-group created for Nexus1000V internal usage. Do not use.
vmware port-group
shutdown
state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
vmware port-group
shutdown
state enabled
port-profile type vethernet VM-client
vmware port-group
no shutdown
state enabled
port-profile type vethernet Vmotion
vmware port-group
switchport access vlan 12
no shutdown
system vlan 12
state enabled
port-profile type vethernet control-packet
vmware port-group
no shutdown
system vlan 1
state enabled
port-profile type ethernet uplink
vmware port-group
switchport mode trunk
switchport trunk allowed vlan 1,10-12,111
no shutdown
system vlan 1,10-12
state enabled
interface Ethernet3/4
inherit port-profile uplink
interface Ethernet4/4
interface mgmt0
ip address 10.2.11.5/24
interface Vethernet1
inherit port-profile L3-control
description VMware VMkernel, vmk2
vmware dvport 32
interface Vethernet2
inherit port-profile control-packet
description Nexus 1000V - VSM, Network Adapter 1
vmware dvport 128
interface Vethernet3
description Nexus 1000V - VSM, Network Adapter 3
vmware dvport 129
interface Vethernet4
vmware dvport 33
interface Vethernet5
inherit port-profile Vmotion
description VMware VMkernel, vmk3
vmware dvport 160
interface Vethernet6
vmware dvport 161
interface Vethernet7
inherit port-profile VM-client
description Windows 7 - A, Network Adapter 1
vmware dvport 192
interface Vethernet8
description Windows 7 - B, Network Adapter 1
vmware dvport 193
interface Vethernet9
inherit port-profile ERSPAN
description VMware VMkernel, vmk4
vmware dvport 224
interface Vethernet10
vmware dvport 225
interface control0
ip address 192.168.1.5/24
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.0.4.SV1.3a.bin sup-1
boot system bootflash:/nexus-1000v-mz.4.0.4.SV1.3a.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.0.4.SV1.3a.bin sup-2
boot system bootflash:/nexus-1000v-mz.4.0.4.SV1.3a.bin sup-2
monitor session 1 type erspan-source
source interface Vethernet7 both
destination ip 192.168.1.12
erspan-id 999
ip ttl 64
ip prec 0
ip dscp 0
mtu 128
header-type 2
no shut
svs-domain
domain id 1
control vlan 1
packet vlan 1
svs mode L3 interface control0
svs connection VC
protocol vmware-vim
remote hostname vcenter.vpod.local port 80
vmware dvs uuid "f7 9e 09 50 bc c8 fc 05-82 39 46 ea 19 50 34 3a" datacenter-n
ame vPod
connect
Nexus1000V#
Solved! Go to Solution.
11-29-2016 12:01 PM
FYI:
Note: We only support a single VMK interface per host to be assigned to the L3capability port-profile.
https://communities.cisco.com/docs/DOC-28631
The configuration that you suggested to us has 2 Vmkernels assign to 2 different L3 port profiles. Seams not supported.
11-29-2016 12:01 PM
FYI:
