Not able to change the port-channel mode from active to passive
mathew.kc1
Not able to change the port-channel mode from active to passive in Nexus 9504, getting below error.
Other end of the interface is connected to Palo Alto Firewall and its configured as LACP mode active. As per the design, Firewall interface should be in active and Nexus switch interface in Passive, we tried to change the Nexus switch interface Eth1/25 to passive and received the below error.
Appreciate your inputs/comments
Error: Cannot add passive-mode port to active-mode port-channel
CGNWKSW01(config)# interface Ethernet1/25
CGNWKSW01(config-if)# channel-group 60 mode passive
Nexus 9504 Configs:
interface port-channel60
  description ## Spine 1 to PaloAlto Firewall 1 ##
  switchport
  switchport mode trunk
  mtu 9216
  vpc 60
  switchport
mtu 9216
  channel-group 60 mode active   -----------> Tried changing to Passive and received the above error
  no shutdown
CGNWKSW01# sh port-channel summ
Flags:  D - Down        P - Up in port-channel (members)
        p - Up in delay-lacp mode (member)
        M - Not in use. Min-links not met
Group Port-       Type     Protocol  Member Ports      Channel
60    Po60(SU)    Eth      LACP        Eth1/25(P)
sh lacp interface Ethernet1/25
Interface Ethernet1/25 is up
  Channel group is 60 port channel is Po60
  PDUs sent: 447006
  PDUs rcvd: 447004
  Markers sent: 0
  Markers rcvd: 0
  Marker response sent: 0
  Marker response rcvd: 0
  Unknown packets rcvd: 0
  Illegal packets rcvd: 0
Lag Id: [ [(7f9b, 0-23-4-ee-be-64, 803c, 8000, 161), (8000, 8-30-6b-b6-b8-1, 10, 8000, 54)] ]
Operational as aggregated link since Thu Feb 27 20:15:29 2020
Local Port: Eth1/25   MAC Address= 70-70-8b-a9-29-ff
  System Identifier=0x8000,  Port Identifier=0x8000,0x161
  Operational key=32828
  LACP_Activity=active
  LACP_Timeout=Long Timeout (30s)
  Synchronization=IN_SYNC
  Collecting=true
  Distributing=true
  Partner information refresh timeout=Long Timeout (90s)
Actor Admin State=61
Actor Oper State=61
Neighbor: 0x54
  MAC Address= 8-30-6b-b6-b8-1
  System Identifier=0x8000,  Port Identifier=0x8000,0x54
  Operational key=16
  Collecting=true
  Distributing=true
Partner Admin State=61
Partner Oper State=61
Aggregate or Individual(True=1)= 1
Mathew
Jason Leschnik
Hi Mathew
Give this a try
Leaf-5(config-if)# channel-group 88 mode active
Leaf-5(config-if)# channel-group 88 mode passive
Leaf-5(config-if)# no channel-group 88 mode active    <<<<<<<<<<<
 HTH!
Jason Leschnik
Hi Mathew
Give this a try
 HTH!
Thanks Jason, it worked
Mathew
     There is another condition that can lead to the same error message. In my case I need to change to active mode:
interface Ethernet1/4
switchport trunk allowed vlan 78
channel-group 1
C3132-ITESYS(config)# int ethernet 1/4
C3132-ITESYS(config-if)# channel-group 1 mode active
Cannot add active-mode port to on-mode port-channel
C3132-ITESYS(config-if)# no channel-group 1
C3132-ITESYS(config-if)# exit
    In this case the reason was another active interface in the same port-channel, in my case the interface eth1/5. So you need to remove the eth1/5 from the port-channel and then proceed with the changes for both.
