NTP not sync nexus 5k
MCCIE
 I am tying to sync my nexus with ntp server. I am able to reach ntp server and also through management vrf but its not syncing.
Not sure if below config is ok or need to add any for nexus 5672
Do it also need to enable feature NTP or is it enabled by default.
please advise
# show running-config ntp
!Command: show running-config ntp
!Time: Thu Mar  7 11:37:01 2019
version 7.1(0)N1(1a)
ntp server 10.1.1.2 prefer use-vrf management
ntp server 10.1.1.3 use-vrf management
system:    version 7.1(0)N1(1a)
# show ntp stat
# show ntp status
Distribution : Disabled
Last operational state: No session
# show ntp peers
  Peer IP Address               Serv/Peer
  10.1.1.2                   Server (configured)
 10.1.1.3                    Server (configured)
# show ntp peer-status
Total peers : 2
* - selected for sync, + -  peer mode(active),
- - peer mode(passive), = - polled in client mode
    remote               local                 st   poll   reach delay   vrf
*10.1.1.2            0.0.0.0                 3   16     377   0.00069 management
=10.1.1.3             0.0.0.0                 3   16     377   0.05183 management
balaji.bandi
hope this solved by now  ?
if not try souurce interface
ntp server 10.10.10.1 use-vrf management
ntp source-interface mgmt0
BB
