orphan-ports
Good afternoon
I am looking for support on the topic "orphan-ports". In an environment with Nexus 7000 I have a vPC configured. This vPC is declared in two interfeces. However, with the "show vpc orphan-ports" command, both the vPC and the interfaces appear to me as orphan-ports in the up state.
What is the reason why I have this output ?....My configuration is the following:
Principal        Secondary
interface port-channel5                                            interface port-channel5
description                                                               description
switchport access vlan 5                                          switchport access vlan 5
spanning-tree port type normal                                 spanning-tree port-priority 128
mtu 9216        spanning-tree port type normal
        mtu 9216
        bandwidth 100000
interface Ethernet1/2                                              interface Ethernet1/2
channel-group 5 mode active                                  mtu 9216
no shutdown                                                           bandwidth 10000000
        no shutdown
interface Ethernet1/3                                               interface Ethernet1/3
the same as Ethernet1/2                                          the same as Ethernet1/2
#show vpc orphan-ports
VPC Role: Primary
VPC Peer-Link Status: Up
Interface Orphan Port Orphan-port
Suspend-config Status
Po5 - Up
Eth1/2 - Up
Eth1/3 - Up
You can support me by checking if I have an error or telling me how I can clean the "orphan-ports"
vedpshar
vPC <vPCnumber> command is missing under port-channel.
Example.
switch(config-if)# vpc 5
Kindly refer below link for better understanding of vPC configuration.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/interfaces/configuration/guide/b-Cisco-Nexus-7000-Series-NX-OS-Interfaces-Configuration-Guide-Book/configuring-vpcs.html
PS: Please don't forget to rate and mark as correct answer if this answered your question.
vedpshar
Example.
