OTV With FHRP
Code_Net
Hello Community,
I have a question about OTV with HSRP, We have two DCs connected by OTV ( the underlay is VPLS ).
We have only one OTV-edge in each DC ( OTV Unicast ), the purpose is to add second OTV edge in both DCs and make the HSRP redundancy.
I want to know if i need to change the OTV mode to multicast, and if there is any config specification for OTV with HSRP, and what is the limitations for OTV over VPLS ?
Thank you all
Steven Doremus
OTV  will work with multicast or unicast as your transport.
Multicast is the preferred method due to its flexibility,as well it's limited overhead.It requires that you have multicast already running as transport in existing network.
You can use  unicast traffic if the total number of sites is less than or equal to two sites.
Thank you Steven, do you have any configuration exemple for OTV Unicast ( 2 ISRs in each DC ) ?
Sergiu.Daniluk
One thing you have to consider about HSRP & OTV, supposing that you have the HSRP configured in conjunction with vPC: you would need to enable HSRP/FHRP isolation, in order to have HSRP Active/Standby in each DC, similar with figure 1-32: https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Data_Center/DCI/whitepaper/DCI3_OTV_Intro/DCI_1.html#wp1186090
You can find config example here:
Step 1. Configure a VLAN ACL (VACL) on the OTV VDC.
ip access-list ALL_IPs 10 permit ip any any mac access-list ALL_MACs 10 permit any any ipv6 access-list ALL_IPV6s 10 permit ipv6 any any ip access-list HSRP_IP 10 permit udp any 224.0.0.2/32 eq 1985 20 permit udp any 224.0.0.102/32 eq 1985 ipv6 access-list HSRP_IPV6 mac access-list HSRP_VMAC 10 permit 0000.0c07.ac00 0000.0000.00ff any 20 permit 0000.0c9f.f000 0000.0000.0fff any 30 permit 0005.73a0.0000 0000.0000.0fff any arp access-list HSRP_VMAC_ARP 10 deny ip any mac 0000.0c07.ac00 ffff.ffff.ff00 20 deny ip any mac 0000.0c9f.f000 ffff.ffff.f000 30 deny ip any mac 0005.73a0.0000 ffff.ffff.f000 40 permit ip any mac any vlan access-map HSRP_Localization 10 match mac address HSRP_VMAC match ip address HSRP_IP match ipv6 address HSRP_IPV6 action drop vlan access-map HSRP_Localization 20 match mac address ALL_MACs match ip address ALL_IPs match ipv6 address ALL_IPV6s action forward feature dhcp ip arp inspection filter HSRP_VMAC_ARP <OTV_Extended_VLANs> vlan filter HSRP_Localization vlan-list <OTV_Extended_VLANs> Step 2. Apply a route-map to the OTV control protocol (ISIS). mac-list OTV_HSRP_VMAC_deny seq 10 deny 0000.0c07.ac00 ffff.ffff.ff00 mac-list OTV_HSRP_VMAC_deny seq 11 deny 0000.0c9f.f000 ffff.ffff.f000 mac-list OTV_HSRP_VMAC_deny seq 12 deny 0005.73a0.0000 ffff.ffff.f000 mac-list OTV_HSRP_VMAC_deny seq 20 permit 0000.0000.0000 0000.0000.0000 route-map OTV_HSRP_filter permit 10 match mac-list OTV_HSRP_VMAC_deny otv-isis default vpn Overlay0 redistribute filter route-map OTV_HSRP_filter
Stay safe,
Sergiu
Hey Segiu,
There is no vPC, the OTV edges are Cisco ISR, do you think that i can configure it in unicast mode ( OTV between 2 ISRs in each DC ), and does VPLS have any limitation for OTV Multicast ?
