Policing in Nexus -bandwidth limitation
rishad ahammed
Beginner
Beginner
  I am trying to implement policing in nexus 5672UP switch.  I want to limit the upload and download bandwidth to 2M on interface vlan 10.
   I have created the policy-map but I am not able to find the "service-policy " command inside the interface.
  Is the are resolution for this ?
David Castro F.
Participant
Participant
Hello Rishad Ahammed,
I hope you are doing great,
It depends on the NX-OS version you have running the MCQ funtionality is available after this release 5.1(3)N2(1) on the Nexus, also if you are getting an issue like "ERROR: QoS Policy on VLAN not allowed,please set interface QoS limit first.", you will need to modify the TCAM limit first:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/qos/521_n1_1/b_5k_QoS_Config_521N11_chapter_01000.html#d2348e346a1635
Keep me posted,
Please rate all the helpful posts and marked as correct if this answered your posts!
David Castro,
That was really helpful. But I can apply policy only in one direction (input) . Since i am trying to limit the bandwidth on both direction i need apply the policy in both inbound and outbound direction.
Please advice
Recognize Your Peers
