Routing between VXLAN and underlay network
neil_titchener
Hi All,
I've setup VXLAN in a test environment and it all looks good with the various tables being populated and inter-subnet routing within VXLAN.  When i ping a host from the underlay network that uses the same IP anycast gateway for inbound and return packets it works fine.  My problem is when i ping a host that uses a different return path i.e. uses a different IP anycast gateway for the return packets it fails.
Does anyone have experience of this?
Cheers
can you share the config
MHM
