Scripting vmkernel port creation - UCS, Nexus 1kv and NFS storage
iniccolai
We have a UCS attached to NetApp storage, all NFS-based. We use NetApp's multi-tenancy functionality(MultiStore), which means a an NFS datastore on a separate VLAN for each tenant. When you have 20+ tenants x a growing number of blades you can't create each vmkernel port manually.
I would like to use VMware's PowerCLI, but it doesn't support the 1kv yet.
Is there any other way I could script this?
Ivan
sachthak
Hi Ivan,
I'm not too familiar with the power cli methods, but it might worth checking out the following API:
Through the VI SDK. The AddVirtualNic method should be able to do this (http://www.vmware.com/support/developer/vc-sdk/visdk400pubs/ReferenceGuide/vim.host.NetworkSystem.html#addVirtualNic)
This should callable through the perl vCLI or the java sdk among other methods
Hope this helps.
Sachin
