04-25-2024 02:22 AM - edited 04-25-2024 02:36 AM
hello
I would like to check if the topology of the images is supported.
having a pair of FEX in dual home and another pair of FEX in single home connected to the same parent switches. Parent switches are nexus 9000.
Separately, both topologies are supported, but it was to be confirmed if both types of FEX to the same parent switches would be supported.
Solved! Go to Solution.
04-25-2024 03:34 AM
No worries, the two types can coexist on N9K.
04-25-2024 03:34 AM
