08-24-2021 07:36 PM
Hi, we are implementing a VxLan EVPN Multisite solution using BGWs between two sites and integrating them with the already
existing nexus 9k legacy-core switches in the environment. Between the BGW and legacy-Core, it is
just a classical ethernet domain with VPC and allowing vlans. The DCI is layer2 port with a SVI peering over eBGP.
Everything seems to be configured properly. I see the nve interface up, eBGP dci underlay is working, evpn peering is up, Vxlan routes are exchanged in the bgp l2vpn evpn table.
On Site1-bgw1, I see the mac-address of Site2-vlan10 learnt over interface nve1 and vice versa on Site2-bgw1, but the cores do not see the mac-address of vlan 10 of the other site. I cannot ping the other site svi/vlan 10. Seems like the BGWs are not sending the mac-address over the VPC Po.
For beverity in the attached diagram, I am only showing single device in each site, but they are actually dual devices.
any suggestions why I cannot ping 10.10.10.2 from site1-core1 and 10.10.10.1 from site2-core1?
03-07-2023 04:07 AM
Hi Sandev
what was the issue, i am having the same problem.
Rohan
03-07-2023 05:30 AM
Hi DCI needs to be a layer 3 routed port.
Peering over SVI is not supported!
