upstream switch link detection not showing
mikeleahy1234
hi guys
i have HP bl 620G7 with 1000v and vsphere 4.1. . when a physical upstream switch port  goes down , my cisco 1000v doesnt notice that its down and when we bring back up the upstream port the vsm port attached to the physical nic does not come up as expected
im using smart link also so i thought this would pass the traffic etc
what teaming method should i use in the port profiles for this to work or would it be a firmware issue on the HP side?
thanks a lot
Robert Burns
Michael,
Good to see you're using smart-link, but also ensure you're using MAC-pinning on the 1000v uplink port profile(s).  When an uplink comes back online, mac-pinning will re-balance the virtual interface pinning among active uplinks.
Assuming you have multiple uplinks to each blade with multiple switch modules in your chassis, do the following:
1. Issue this command: "module vem x execute vemcmd show port".  This will show you the sub-group IDs for all vmnics and the sub-group of each virtual interface.
2. Shutdown the uplink and repeat the command.  You should all virtual interfaces pinned to "other" sub-group IDs than the one you just shut down.
3. Re-enable the uplink and repeat again.  You should see virtual interfaces re-pinned back to this SG.
Ex.
n1000v-BL1(config)# module vem 3 execute vemcmd show port
  LTL   VSM Port  Admin Link  State  PC-LTL  SGID  Vem Port
   17     Eth3/1     UP   UP    FWD     305     0  vmnic0  <==== Physical Uplink 1 = Sub Group ID 0
   18     Eth3/2     UP   UP    FWD     305     1  vmnic1  <==== Physical Uplink 2 = Sub Group ID 1
   49      Veth4     UP   UP    FWD       0     0  vmk0
   50     Veth11     UP   UP    FWD       0     1  vmk1
   51      Veth1     UP   UP    FWD       0     0  vmk2
   52      Veth6     UP   UP    FWD       0     0  vCenter 4.1.eth0   <===All virtual interfaces have SG 1 or 0
   55     Veth18     UP   UP    FWD       0     0  WIN2K3-DC ethernet0
   56     Veth25     UP   UP    FWD       0     1  n1000v-BL1-Secondary.eth2
   57     Veth24     UP   UP    FWD       0     1  n1000v-BL1-Secondary.eth1
   58     Veth19     UP   UP    FWD       0     1  n1000v-BL1-Secondary.eth0
   59     Veth10     UP   UP    FWD       0     0  n1000v-BL1-Primary.eth2
   60      Veth9     UP   UP    FWD       0     0  n1000v-BL1-Primary.eth1
   61      Veth8     UP   UP    FWD       0     0  n1000v-BL1-Primary.eth0
   62      Veth5     UP   UP    FWD       0     1  Sharepoint-CAE ethernet0
  305        Po2     UP   UP    FWD       0
After diabling the Uplink
   17     Eth3/1   DOWN DOWN    BLK     305     0  vmnic0  <==== Physical Uplink 1 shows down
   49      Veth4     UP   UP    FWD       0     1  vmk0
   51      Veth1     UP   UP    FWD       0     1  vmk2
   52      Veth6     UP   UP    FWD       0     1  vCenter 4.1.eth0   <===All virtual interfaces have SG of 1
   55     Veth18     UP   UP    FWD       0     1  WIN2K3-DC ethernet0
   59     Veth10     UP   UP    FWD       0     1  n1000v-BL1-Primary.eth2
   60      Veth9     UP   UP    FWD       0     1  n1000v-BL1-Primary.eth1
   61      Veth8     UP   UP    FWD       0     1  n1000v-BL1-Primary.eth0
  305        Po2     UP   UP    FWD       0
Which version of 1000v are you using btw?
Robert
robert
thanks for that but if i plug  the actual physical uplink out of the physical switch then the nexus will still display it as up, not down.
If when you disconnect all the uplinks from the VC module in the chassis and the hosts don't see a link down event
(You can confirm by "ifconfig" or "esxcfg-nics -l") then either there's an issue with the VC module or Smart-Link isn't operating as it should.  In this case you'd need to follow up with HP.
If the host doesn't detect the link down, the 1000v can't respond accordingly....
Robert
