Valid copper SFP that will operate at 10/100/1000mb that is compatible with a Nexus 7k
clive.hodgetts
I am finding it very difficult to identify a 1gb base-T SFP that is compatible with a Nexus 7k and will negotiate speeds of 10/100/1000mb. I know this is quite old technology and best practice is not to utilise 7k interfaces to directly connect low speed (10/100mb) switches/hosts. Does anyone know of a trusted part number which will negotiate at 10/100/1000mb and is compatible with the 7k's?
The Nexus module part number is: N77-F348XP-23 and the NX-OS version is:  6.2(12)
Any advice will be appreciated.
Clive
Christopher Hart
Hi Clive,
The Cisco Optics-to-Device Compatibility Matrix tool is the best place to verify what specific transceiver models fit your needs. Specifically, for an N77-F348XP-23 line card in a device running NX-OS software release 6.2(12), you have the following options:
  • GLC-T (EoS/EoL)
  • SFP-GE-T (EoS/EoL)
  • GLC-TE
If you already have any of the above transceivers and face difficulties with getting them to operate at 10/100Mbps speeds, we can certainly try to troubleshoot that issue as well.
I hope this helps - Thank you!
-Christopher
Christopher Hart
Hi Clive,
  • GLC-T (EoS/EoL)
  • GLC-TE
-Christopher
Hi Christopher,
The SFP's the customer has at the DC are GLC-T-C which don't allow for speed negotiation. The SFP's you have listed we do have in stock so we will install one of those types and re-test.....
Thanks for your quick response and invaluable information supplied
Cheers,
Clive
