VXLAN ESI issue
verma-rohit
hi, I am trying to establish ESI between Swicth5 and leaf swicthes, NXOS2 and NXOS3, but for some reason, it fails on swicth 5. It comes up for a minute and then goes down citing "channel-misconfig (STP) error detected on Po10".
Code on NXOS: nxos.9.3.10.bin
Code on vIOS: vios_l2-adventerprisek9-m
Note: I have attached  show run as an attachment. Shared below is the design.
NXOS2
interface port-channel10
  switchport mode trunk
  switchport trunk allowed vlan 100,200
  ethernet-segment 1234
    system-mac 0000.0000.2011
interface Ethernet1/3
  channel-group 10 mode active
Spanning tree config
spanning-tree mode mst
spanning-tree domain enable
spanning-tree mst 0-1 priority 8192
spanning-tree mst configuration
  name VXLAN-FABRIC
  instance 1 vlan 100,200
LEAF-101(config)# show spanning-tree summary
Switch is in mst mode (IEEE Standard)
L2 Gateway Domain ID: 1
Port Type Default                        is disable
Edge Port [PortFast] BPDU Guard Default  is disabled
Edge Port [PortFast] BPDU Filter Default is disabled
Bridge Assurance                         is enabled
Loopguard Default                        is disabled
Pathcost method used                     is long
PVST Simulation                          is enabled
STP-Lite                                 is disabled
NXOS3
  name VXLAN-FABRIC
LEAF-102# show spanning-tree summary
Swicth5
*Jun  3 11:46:54.085: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po10, putting Gi0/0 in err-disable state
*Jun  3 11:46:54.088: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po10, putting Gi0/1 in err-disable state
*Jun  3 11:46:54.091: %PM-4-ERR_DISABLE: channel-misconfig (STP) error detected on Po10, putting Po10 in err-disable state
*Jun  3 11:46:55.086: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Jun  3 11:46:55.088: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
*Jun  3 11:46:56.088: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
*Jun  3 11:46:56.090: %LINK-3-UPDOWN: Interface Port-channel10, changed state to down
*Jun  3 11:46:56.091: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
*Jun  3 11:46:57.090: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel10, changed state to down
show interface status , when po 10 was up
Port      Name               Status       Vlan       Duplex  Speed Type
Gi0/0                        connected    trunk      a-full   auto RJ45
Gi0/1                        connected    trunk      a-full   auto RJ45
Spanning tree configuration
 name VXLAN-FABRIC
 instance 1 vlan 100, 200
spanning-tree mst 0-1 priority 61440
FEX-1#show run int gig 0/0
Building configuration...
Current configuration : 145 bytes
interface GigabitEthernet0/0
 negotiation auto
end
Interface configuration
FEX-1#show run int gig 0/1
interface GigabitEthernet0/1
 negotiation auto
end
FEX-1#show run int po 10
Current configuration : 93 bytes
interface Port-channel10
end
verma-rohit
Attaching running configuration
