VxLAN - vrf leaking
grey_death
Ciao,
let's assume that I have a very high number of VRF (more than 40) in a VxLAN fabric: which will be the best solution to put toghether all the VRF in a shared one (only one) ?
The requirement is to not pass trought a firewall so we are thinking to use a phisical cable to achieve this; something that works fine, for example, for QinQ in VPLS.
Is this supported ? Does somebody already try this ?
Best,
L.
nazimkha
I am not sure what is ultimate goal but you can if you are looking to leak some routing out of the VXLAN fabric you can try this
VXLAN Fabric with all VRF's------External Route peering--------Core switch (No segmentation i,e no VRFs)---Internet/WAN
Ciao,
for sure that will work ... but we cannot use external hw to do leaking
Best,
L.
