which N9K are EOR and TOR?
gavinhans
which N9K are EOR and TOR? what's the best way to classifly?
Christopher Hart
Hello!
TOR means "Top of Rack", while EOR means "End of Row". All Nexus 9500 switches are considered modular EOR chassis, as they have field-replaceable supervisors, line cards, and fabric modules. All other Nexus 9000 switches are considered TOR chassis.
I hope this helps! Thank you!
-Christopher
Sergiu.Daniluk
Hi @gavinhans
In addition to what @Christopher Hart mentioned, just wanted to say that Nexus 9300 are excellent ToR switch, but they can also be designed to work as EoR or MoR (Middle-of-Row). Nexus 9000 switches support the Nexus 2000 Fabric Extenders (FEX), so you can use FEXs as ToR (usually 2 of them for redundancy).
Stay safe and Rack-and-Roll!
Sergiu
