ā12-30-2024 09:47 AM
Hi, is there options to provide Duo authentication for O365, for users that use thin clients with non-persistent desktops and do not have access to a company mobile device. They may have their own mobile, but I don't want them to use that. Is there some type of application from Duo or other that I can install onto the Gold image of the VDI that can facilitate the MFA?
Thanks.
ā12-31-2024 07:17 AM
have you considered using passkeys? something like a yubikey or swissbit might work.
ā01-02-2025 07:48 AM
I'm trying the Yubikey Nano5 right now, but it looks like I have to enable TPM on the vm's. I'm not sure if my current hardware supports that and if it does, looks like I'll have to cook up a new Gold Image.
ā01-02-2025 08:05 AM
You might want to explore Duo's web SDK
The Duo Web SDK is a JavaScript library that can be integrated into your O365 login pages. This allows users to perform Duo Push, Duo Phone, or other Duo authentication methods directly within their web browser on the thin client.
or check if the YubiKeys can still be used as hardware tokens for 2FA, even without relying on TPM for passkey functionality
check with your hypervisor vendor. Good luck
ā01-02-2025 08:06 AM
here's the link to the Duo SDK info
