CMX 10.2 and MSE
R2C CCIE/CWNE
Is it possible to have both a MSE8.0 and CMX 10.2 running CAS? If so will it need AP licenses for both instances?
matfarre
Level 6
Level 6
Yes, the MSE license is transferable to CMX and both versions will be fully operational.  No, you will not need additional AP license to operate both systems.  Since there is not a direct upgrade path from MSE to CMX, Cisco CMX folks suggest running both versions in parallel during a transition from MSE to CMX 10. Then, only when CMX is stable, to retire the MSE system.
Thanks for the question,
Matt
