09-25-2022
12:04 AM
- last edited on
03-17-2023
06:56 AM
by
Paul Zimmerman
I'm going to setup automation system
(transport input ssh) command is it helping to be a good automation or I need it to have it for connectivity?
09-25-2022 01:19 AM
@YazeedAshrafi yes you would need it for automation purposes, you'd also want it to remotely connect to the device for management purposes.
09-25-2022 05:48 AM
yes. if your automation service (most of the times) using SSH to connect to device.
09-25-2022 09:18 AM
My question is about only this command (transport input ssh), I have to use this command?
Knowing I new all the commands for ssh connectivity.
09-25-2022 08:06 PM
yes. better avoid unencrypted transports like telnet. using that command you only enabling SSH to connect with devices
09-26-2022 02:05 AM
What I mean if I didn't add this command the automation system would make connectivity with out it?
