02-11-2019 08:11 PM - edited 06-04-2019 02:46 AM
Greetings
I can get on to the APIC with provided credentials but these same credentials do not work for vSphere access.
I can get to the prompt so it looks like it is up.
No credentails are visible to me as per screenshot below.
Greatly appreciate any help due to tight time constraints :)
Once again my thanks for any responses
Solved! Go to Solution.
02-11-2019 11:51 PM
Hi Juan,
Have you checks https://devnetsandbox.cisco.com/Docs/ACI_Sandbox/ACI-Sandbox-TopologyV1.23c.pdf , which lists creds to be using in this sandbox.
Bob
02-11-2019 08:42 PM
02-11-2019 11:51 PM
Hi Juan,
Bob
02-12-2019 02:37 AM
Hi Zowu
Thank you so much for replying.
I am assuming I should have found that PDF will go back later and see if I can locate it for next time.
I still have a problem however with vSphere credentials are not working as advertised.
Also notice the vSphere client
See below.
Will check other credentials and update this blog
02-12-2019 02:46 AM
Zowu - thank you. I have the access that I need
Summary:
Ubuntu host Putty - Working
APIC - (Was always) Working. Credentials in the Lab overview tab posted above
RDP working to 10.10.10.99. vSphere is open on the machine.
Repeat - I am good and thankyou for the PDF.
All good!
