03-27-2017 06:02 PM - edited 06-04-2019 02:29 AM
When I checked the interface status of ETH1/1 on FXOS CLI, it says port is not connected and it is supposed to be the management interface of ASA. Whom to contact to correct this?
03-27-2017 11:39 PM
Hi Mohan
We will check the interface this morning and get back to you.
Joe
Sent from my Samsung Galaxy smartphone.
03-28-2017 03:47 AM
Hi Mohan,
I checked the reservations this morning and your reservation ended earlier today.
Can you reserve the Firepower clustered chassis topology again? Once it is up we can look at your issue.
Joe
03-28-2017 08:55 AM
I tried to use the ASA clustering on the Firepower Chassis Manager lab. Tried multiple different things to bring clustering in the second box, 10.10.20.31.
1. I remove Eth1/1 as the management interface of ASA and added only Eth1/4 as it was the working port.
2. When trying to join the existing cluster on 10.10.20.31, Firepower Chassis Manager, I was receiving following errors.
3. Port type were similar to the 10.10.20.30 box, but for some reason it was constantly throwing this error.
03-31-2017 06:30 AM
Hi Sailendra,
Apologies for the delayed response on this one. We are currently investigating this and it may require that we baseline the lab again.
We will get back to you shortly with an update.
Joe
