Setting up sandbox for MRCP testing
a.belozerchick
Hi!
We would like to setup Cisco sandbox for testing our MRCP implementation.
We deployed our MRCP sevices (for ASR and TTS) in our local environment
and have managed to establish VPN connection between our virtual machines
and Cisco Sandbox. But we do not understand how we can setup Cisco Sandbox
in a way it could send MRCP requests and RTP to our virtual machines.
Is it possible?
kkhlebop
The sandboxes have tight security before and after the VPN connection. The security is applied on outbound communication and inbound communication. The only inbound communication that works before the VPN is established is just the VPN connection itself. Then after connecting via the VPN there are limitations due to security. SSH and RDP to most of the hosts are allowed, however, outbound communication from within the sandbox to your local network via VPN is secured down. Even after the VPN is established there is tight security.
@kkhlebop, thank you! So there is no way to test our MRCP solution with Cisco using sandbox?
Uploading our software to the sandbox is also impossible?
