el 01-15-2024 03:57 AM
Hi community,
I am configuring a SG200 switch for integration with a NAC, I want to authenticate users (802.1X) and phones (MAC), so I need to configure ports with "802.1X and MAC" option. According to the switch guide this is possible
But in my switch I don't find this option:
The guide is for version 1.3.0.62, and the switch has version 1.3.7.18.
Any idea?
Julián
el 01-15-2024 04:34 AM
Small model like 200 does not support that feature i guess : (datasheet shows only 802.1x)
el 01-17-2024 12:50 AM
Yes,
Documentation is confusing, because 802.1X Port Authentication Configuration on Cisco 200/300 Series Managed Switches says Applicable Devices: SF/SG 200 and SF/SG 300 Series Managed Switches.
el 01-17-2024 03:00 AM
Sometime Cisco documents are not updated as expected. (if you verify with other document and you have device which do not have that option) - that indicates that this feature not supported.
For Clarity you can call SMB TAC case and ask - https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
01-15-2024 05:44 AM - editado 01-15-2024 06:42 AM
that weird
open TAC for this case
MHM
el 01-15-2024 06:37 AM
that wired?
el 01-15-2024 06:43 AM
doc. you share mention 200 series but the option not appear.
that weird and also the ver. you run higher.
anyway open TAC to more sure that is platform limitation or it bug
MHM
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
