el 08-09-2018 07:49 AM
Buen día.
de antemano gracias por permitirme publicar en este foro.
tengo una duda sobre los MIBs del ARS 1001-X.
eh buscado y solo encuentro información concreta de los MIBs de procesador y memoria de los ARS, y me gustaría saber si alguien me puede apoyar, si tienen información de MIBs de Temperatura y Fuentes de poder.
Gracias.
el 08-09-2018 09:32 AM
Hola,
Esto encontré en un datasheet del SR1001-X.
Espero que te sirva.
Saludos
Table 5. Cisco ASR 1000 Series Processor Module Comparison and Specifications
Cisco ASR 1000 Series |
Cisco ASR 1001-X |
Rack-mounting |
Yes: 19-inch |
Wall-mounting |
No |
External USB flash memory |
1-GB USB flash-memory support |
Redundant power supply |
Yes: Dual power supplies by default; option of either AC or DC power supply Note: A mix of one AC and one DC power supply is not supported. |
Power input |
Worldwide ranging AC input range (85 to 264 VAC) Worldwide ranging DC (-40 to -72V; 48V nominal) |
Power consumption |
● Maximum (DC): 242W ● Maximum (AC): 250W ● Maximum (out): 250W |
Airflow |
Front-to-back |
Operating temperature (nominal) |
32 to 104°F |
Operating temperature (short-term) |
32 to 122°F |
Operating humidity (nominal) (relative humidity) |
10 to 85% |
Operating humidity (short-term) |
5 to 90% |
Storage temperature |
-40 to 150°F (-40 to 70°C) |
Storage humidity (relative humidity) |
5 to 95% |
Operating altitude |
-500 to 10,000 feet |
Network Equipment Building Standards (NEBS) |
GR-1089 and GR-63 |
EMC standards |
● FCC 47 CFR Part 15 Class A ● VCCI Class A ● AS/NSZ Class A ● ICES-003 Class A ● EN55022/CISPR 22 Information Technology Equipment ● (Emissions) ● EN55024/CISPR 24 Information Technology Equipment ● (Immunity) ● EN300 386 Telecommunications Network Equipment ● (EMC) ● EN50082-1/EN61000-6-1 Generic Immunity Standard |
Safety Standard |
UL60950-1 CSA C22.2 No. 60950-1-03 EN 60950-1 IEC 60950-1 AS/NZS 60950.1 |
el 08-09-2018 10:17 AM
el 08-09-2018 12:52 PM
Hola Krause,
Creo que para los ASR1K los valores SNMP de Power Supply y Temperature estan en la MIB CISCO-ENTITY-SENSOR-MIB, por favor revisa los siguientes links:
ftp://ftp.cisco.com/pub/mibs/supportlists/asr1000/asr1000-supportlist.html#_Changes_from_IOS
https://community.cisco.com/t5/routing/problem-with-sensor-temperature-asr-1000/td-p/1720925
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/mib/guide/asr1kmib/asr1mib3.html#84985
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/mib/guide/asr1kmib.pdf
Por favor no olvides calificar las respuestas útiles.
Saludos,
el 08-09-2018 01:16 PM
Descubra y salve sus notas favoritas. Vuelva a encontrar las respuestas de los expertos, guías paso a paso, temas recientes y mucho más.
¿Es nuevo por aquí? Empiece con estos tips. Cómo usar la comunidad Guía para nuevos miembros
Navegue y encuentre contenido personalizado de la comunidad
