Problem with Sensor Temperature ASR 1000
RonaldJCM
I am monitoring a Router ASR 1000 with a monitoring software called zenoss, this software works with the SNMP agent, when I tried to get the temperature graph from the router, it dont show me anything, i believe that the router didnt recognize the temperature Oid from zenoss, in this case
1.3.6.1.4.1.9.9.13.1.3.1.3
What can i do to achive that the ASR 1000's sensor temperature show me the value?
how can i active the sensor temperute in this router (ASR 100)?
Soraya Golbeg
Hi Ronald,
The 1.3.6.1.4.1.9.9.13.1.3.1.3 OID is part of the CISCO-ENVMON-MIB.
This MIB is not supported on the ASR.
For this platform, it would be better to use the CISCO-ENTITY-SENSOR-MIB:
http://www.cisco.com/en/US/partner/docs/routers/asr1000/mib/guide/asr1mib3.html#wp2089514
You would specifically be interested in the following OIDS:entSensorType and entSensorValue.
The 'sh env all' will allow you to check if you are retrieving the right values.
Hope this helps!
Cheers,
soraya
5 Replies 5
Soraya Golbeg
Hi Ronald,
Hope this helps!
Cheers,
soraya
I am monitoring a Router ASR1000 with a software called Zenoss, which works with SNMP Agent. In Zenoss I am using The
1.3.6.1.4.1.9.9.91.1.1.1.1.4 OID (entSensorValue) to get the  values of many sensors in the device (ASR1000). the Sensor Values, which  I get in the router are:
ASR-ROSAL-01#sh environment all
Sensor List:  Environmental Monitoring
Sensor           Location          State             Reading
V1: VMA          1                 Normal            1098 mV
V1: VMB          1                 Normal            1196 mV
V1: VMC          1                 Normal            1499 mV
V1: VMD          1                 Normal            1791 mV
V1: VME          1                 Normal            2495 mV
V1: VMF          1                 Normal            3291 mV
V1: 12v          1                 Normal            11953 mV
V1: VDD          1                 Normal            3295 mV
V1: GP1          1                 Normal            754 mV
V1: GP2          1                 Normal            900 mV
V2: VMB          1                 Normal            1196 mV
V2: 12v          1                 Normal            11938 mV
V2: VDD          1                 Normal            3300 mV
V2: GP2          1                 Normal            905 mV
Temp: Left       1                 Normal            22 Celsius
Temp: Center     1                 Normal            24 Celsius
Temp: Asic1      1                 Normal            35 Celsius
Temp: Right      1                 Normal            20 Celsius
V1: VMA          F1                Normal            1796 mV
V1: VMB          F1                Normal            1196 mV
V1: VMC          F1                Normal            1196 mV
V1: VMD          F1                Normal            1098 mV
V1: VME          F1                Normal            1000 mV
V1: VMF          F1                Normal            747 mV
V1: 12v          F1                Normal            11923 mV
V1: VDD          F1                Normal            3305 mV
V1: GP1          F1                Normal            905 mV
V2: VMA          F1                Normal            3291 mV
V2: VMB          F1                Normal            2495 mV
V2: VMC          F1                Normal            1494 mV
V2: VMD          F1                Normal            1196 mV
V2: VME          F1                Normal            1098 mV
V2: VMF          F1                Normal            996 mV
V2: 12v          F1                Normal            11865 mV
V2: VDD          F1                Normal            3305 mV
V2: GP1          F1                Normal            749 mV
Temp: Inlet      F1                Normal            24 Celsius
Temp: Asic1      F1                Normal            37 Celsius
Temp: Exhaust1   F1                Normal            35 Celsius
Temp: Exhaust2   F1                Normal            36 Celsius
Temp: Asic2      F1                Normal            30 Celsius
V1: VMA          F0                Normal            1791 mV
V1: VMB          F0                Normal            1191 mV
V1: VMC          F0                Normal            1196 mV
V1: VMD          F0                Normal            1098 mV
V1: VME          F0                Normal            996 mV
V1: VMF          F0                Normal            747 mV
V1: 12v          F0                Normal            11923 mV
V1: VDD          F0                Normal            3305 mV
V1: GP1          F0                Normal            908 mV
V2: VMA          F0                Normal            3291 mV
V2: VMB          F0                Normal            2495 mV
V2: VMC          F0                Normal            1499 mV
V2: VMD          F0                Normal            1201 mV
V2: VME          F0                Normal            1098 mV
V2: VMF          F0                Normal            996 mV
V2: 12v          F0                Normal            11850 mV
V2: VDD          F0                Normal            3305 mV
V2: GP1          F0                Normal            749 mV
Temp: Inlet      F0                Normal            23 Celsius
Temp: Asic1      F0                Normal            38 Celsius
Temp: Exhaust1   F0                Normal            36 Celsius
Temp: Exhaust2   F0                Normal            36 Celsius
Temp: Asic2      F0                Normal            30 Celsius
V1: VMA          0                 Normal            1093 mV
V1: VMB          0                 Normal            1201 mV
V1: VMC          0                 Normal            1499 mV
V1: VMD          0                 Normal            1796 mV
V1: VME          0                 Normal            2495 mV
V1: VMF          0                 Normal            3291 mV
V1: 12v          0                 Normal            11953 mV
V1: VDD          0                 Normal            3300 mV
V1: GP1          0                 Normal            751 mV
V1: GP2          0                 Normal            900 mV
V2: VMB          0                 Normal            1196 mV
V2: 12v          0                 Normal            11923 mV
V2: VDD          0                 Normal            3295 mV
V2: GP2          0                 Normal            900 mV
Temp: Left       0                 Normal            23 Celsius
Temp: Center     0                 Normal            26 Celsius
Temp: Asic1      0                 Normal            36 Celsius
Temp: Right      0                 Normal            21 Celsius
PEM Iout         P0                Normal            17 A
PEM Vout         P0                Normal            12 V AC
PEM Vin          P0                Normal            121 V AC
Temp: PEM        P0                Normal            25 Celsius
Temp: FC         P0                Fan Speed 65%     18 Celsius
PEM Iout         P1                Normal            17 A
PEM Vout         P1                Normal            12 V AC
PEM Vin          P1                Normal            119 V AC
Temp: PEM        P1                Normal            25 Celsius
Temp: FC         P1                Fan Speed 65%     17 Celsius
V1: VMA          R0                Normal            1103 mV
V1: VMB          R0                Normal            3295 mV
V1: VMC          R0                Normal            2495 mV
V1: VMD          R0                Normal            1796 mV
V1: VME          R0                Normal            1499 mV
V1: VMF          R0                Normal            1206 mV
V1: 12v          R0                Normal            11909 mV
V1: VDD          R0                Normal            3281 mV
V1: GP1          R0                Normal            903 mV
V1: GP2          R0                Normal            1228 mV
Temp: CPU        R0                Normal            25 Celsius
Temp: Outlet     R0                Normal            24 Celsius
Temp: Inlet      R0                Normal            17 Celsius
Temp: Asic1      R0                Normal            25 Celsius
V1: VMA          R1                Normal            1113 mV
V1: VMB          R1                Normal            3315 mV
V1: VMC          R1                Normal            2519 mV
V1: VMD          R1                Normal            1806 mV
V1: VME          R1                Normal            1508 mV
V1: VMF          R1                Normal            1215 mV
V1: 12v          R1                Normal            11967 mV
V1: VDD          R1                Normal            3295 mV
V1: GP1          R1                Normal            908 mV
V1: GP2          R1                Normal            1259 mV
Temp: CPU        R1                Normal            24 Celsius
Temp: Outlet     R1                Normal            24 Celsius
Temp: Inlet      R1                Normal            17 Celsius
Temp: Asic1      R1                Normal            23 Celsius
I woulk like to know which of this Values in the list is the device's temperature (Chassis temperature)? and what is the specific Oid to get that particular Value (Chassis temperature)?
I was wondering What is the health range of the device's temperature (Router ASR1000)? what is the value of temperature which i can take as threshold to the router ASR1000?
You can find the Names to the Values int the entPhysicalTable.
OID: 1.3.6.1.2.1.47.1.1.1
For Inlet This would be:
SNMPv2-SMI::mib-2.47.1.1.1.1.7.7031 = STRING: "Temp: Inlet R0/30"
With the Value:
SNMPv2-SMI::enterprises.9.9.91.1.1.1.1.4.7031 = INTEGER: 25
RonaldJCM
thank you!
mhiyoshi
Level 3
Level 3
Hello Soraya
Please let me know more detail of this tips.
CISCO-ENVMON-MIB itself is unsupported, but the substitution is CISCO-ENTITY-SENSOR-MIB on ASR 1K right?
Best Regards,
Masanobu Hiyoshi
