cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
ASR 1001-X
Krause
Buen día.
de antemano gracias por permitirme publicar en este foro.
tengo una duda sobre los MIBs del ARS 1001-X.
eh buscado y solo encuentro información concreta de los MIBs de procesador y memoria de los ARS, y me gustaría saber si alguien me puede apoyar, si tienen información de MIBs de Temperatura y Fuentes de poder.
Gracias.
4 RESPUESTAS 4
luis_cordova
Hola,
Esto encontré en un datasheet del SR1001-X.
Espero que te sirva.
Saludos
Table 5.       Cisco ASR 1000 Series Processor Module Comparison and Specifications
Cisco ASR 1001-X
Rack-mounting
Yes: 19-inch
Wall-mounting
No
External USB flash memory
1-GB USB flash-memory support
Redundant power supply
Yes: Dual power supplies by default; option of either AC or DC power supply
Note: A mix of one AC and one DC power supply is not supported.
Power input
Worldwide ranging AC input range (85 to 264 VAC)
Worldwide ranging DC
(-40 to -72V; 48V nominal)
Power consumption
●  Maximum (DC): 242W
●  Maximum (AC): 250W
●  Maximum (out): 250W
Airflow
Front-to-back
Operating temperature (nominal)
32 to 104°F
(0 to 40°C)
Operating temperature (short-term)
32 to 122°F
(0 to 50°C)
Operating humidity (nominal) (relative humidity)
10 to 85%
Operating humidity (short-term)
5 to 90%
Storage temperature
-40 to 150°F
(-40 to 70°C)
Storage humidity (relative humidity)
5 to 95%
Operating altitude
-500 to 10,000 feet
(152 to 3048 meters)
Network Equipment Building Standards (NEBS)
GR-1089 and GR-63
EMC standards
●  FCC 47 CFR Part 15 Class A
●  VCCI Class A
●  AS/NSZ Class A
●  ICES-003 Class A
●  EN55022/CISPR 22 Information Technology Equipment
●  (Emissions)
●  EN55024/CISPR 24 Information Technology Equipment
●  (Immunity)
●  EN300 386 Telecommunications Network Equipment
●  (EMC)
●  EN50082-1/EN61000-6-1 Generic Immunity Standard
Safety Standard
UL60950-1
CSA C22.2 No. 60950-1-03
EN 60950-1
IEC 60950-1
AS/NZS 60950.1
Krause
Si, gracias... ya había visto la información del datasheet, sin embargo, me interesa mas el SNMP MIBs para el monitoreo de temperatura y fuentes de poder.
Diana Karolina Rojas
Hola Krause,
Creo que para los ASR1K los valores SNMP de Power Supply y Temperature estan en la MIB CISCO-ENTITY-SENSOR-MIB, por favor revisa los siguientes links:
ftp://ftp.cisco.com/pub/mibs/supportlists/asr1000/asr1000-supportlist.html#_Changes_from_IOS
https://community.cisco.com/t5/routing/problem-with-sensor-temperature-asr-1000/td-p/1720925
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/mib/guide/asr1kmib/asr1mib3.html#84985
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/mib/guide/asr1kmib.pdf
Por favor no olvides calificar las respuestas útiles.
Saludos,
Krause
Hola Diana.. gracias por la info, algo de ello ya había visto y leído. quizá no puse mucha atención a la parte de sensores.
