cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
CBS 350 Series Managed Switches boot in Linux mode
jmhalegre
Hi Team,
I have a cbs350-24fp-4g switch booting in Linux mode as shown below:
BootROM 1.41
Booting from SPI flash
General initialization - Version: 1.0.0
Serdes initialization - Version: 1.0.2
mvCtrlPexPolaritySet: TWSI Write skipped, leaving PEX polarity in EP mode
PEX: pexIdx 0, detected no link
DDR3 Training Sequence - Ver TIP-1.57.0
mvSysEnvGetTopologyUpdateInfo: skipped Twsi read to enable DDR ECC update
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
Msys Booton: Sep 7 2021 00:40:16 ver 3.1.6
Secure Boot: ON
Press x to choose XMODEM...
Booting from NAND flash
Secure Boot: Verify U-Boot secure imageSecure Boot: getBootonSecureHeader
image sha256: 7E6349D8845BD171B1664CE1F1AD49D635EAE94EFC7DF4C424FAA2834B8AFF0C
Verify secure U-Boot (1-1) pass
Running UBOOT...
U-Boot 2013.01 (Feb 13 2023 - 01:10:46) Version: armada-17.06.6 V3.2.1.22
NAND ID = 0xDA01
NAND Model = Cypress/Spansion 2Gb 8bit S34ML02G2
EZ1K secure board
CBS350-24FP-4G
FPGA Version: 34.25
uboot sha256 calculated by booton: 7E6349D8845BD171B1664CE1F1AD49D635EAE94EFC7DF4C424FAA2834B8AFF0C
Loading file 'mfg.bin' to addr 0x02000000 with size 27727739 (0x01a7177b)...
Done
image_size 27727739
Headers block RSA signature verification - PASSED
image sha256: ACC217182876B8021CBD7E432CBF1D400F1A9AA4C7D07EA4D802B29C38740C1E
Verify MFG secure image pass
Loading MFG
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Linux_Image
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 27717975 Bytes = 26.4 MiB
Load Address: 00008000
Entry Point: 00008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
ln: console: File exists
ln: tty: File exists
ln: ttys0: File exists
ln: tty5: File exists
ln: tty1: File exists
Sun Nov 7 09:29:00 UTC 2021
Linux MARVELL_LINUX 4.14.76-19.0.0 #124 SMP Thu Feb 10 15:11:14 CST 2022
Welcome to Embedded Linux
_ _
| ||_|
| | _ ____ _ _ _ _
| || | _ \| | | |\ \/ /
| || | | | | |_| |/ \
|_||_|_| |_|\____|\_/\_/
On Marvell's ARM board
For further information on the Marvell products check:
http://www.marvell.com/
toochain=gnueabi
Enjoy!
ubiattach: UBI_IOCATT: No such device
commander: threads are running: luaCLI cmdShell
Failed to get config.txt.10.4.50.165 from 10.4.50.5: timeout waiting ack
Failed to get config.txt from 10.4.50.5: timeout waiting ack
Prestera commander shell server ready
FPGA set TX_DISABLE, 0x7=0x0
FPGA Reset Control, Reset USB, All PHYs 0xB=0x01FF
run TI PoE Dragnoite Sample 2219
prvExtDrvMbusConfigure 242 gpio_isr:41
Warning:Tried to allocate 3318036 which is bigger than the memory chunk size.
Device[0] ID 0xF41C11AB revision A1
Core clock = 290Mhz
, Pass board info = 0x93
CPSS xcat3PortInterfaceInit: Read xCAT3 MAC chip id 0xF41C
cpssInitSystem time: 0 sec., 454352800 nanosec.
Time processing the cpssInitSystem (from 'phase1 init') is [0] seconds + [383958880] nanoseconds
run TI PoE Dragnoite Sample 2634appDemoDragoniteSoftwareDownload: read file size = 63156
run TI PoE Dragnoite Sample 2639DBG: switch_halBoardIDInit-- get board id value 0x93
DBG: (sys_utilsDevBoardIdGet) the switch board is EZ1K_24G4G_P
Fail to open the CommitID file.
Initialize GPIO ...
Init EZ1K_24G4G_P qsgmii config
QSGMII parameter fine tune Done
Initialize PoE ...
requestLen = 49
Request with opcode = 0x02000100 :
18 01 00 02 | 01 03 02 04 | 03 05 04 06 | 05 07 06 08 |
07 09 08 0a | 09 0b 0a 0c | 0b 0d 0c 0e | 0d 0f 0e 10 |
0f 11 10 12 | 11 13 12 14 | 13 15 14 16 | 15 17 16 18 |
17
requestLen = 49
Request with opcode = 0x00000101 :
18 01 03 02 | 03 03 03 04 | 03 05 03 06 | 03 07 03 08 |
03 09 03 0a | 03 0b 03 0c | 03 0d 03 0e | 03 0f 03 10 |
03 11 03 12 | 03 13 03 14 | 03 15 03 16 | 03 17 03 18 |
03
requestLen = 49
Request with opcode = 0x0b000100 :
10 00 02 e4 | 01 02 e4 02 | 02 e4 03 02 | e4 04 02 e4 |
05 02 e4 06 | 02 e4 07 02 | e4 08 02 e4 | 09 02 e4 0a |
02 e4 0b 02 | e4 0c 02 e4 | 0d 02 e4 0e | 02 e4 0f 02 |
e4
requestLen = 2
Request with opcode = 0x02000101 :
ff 00
requestLen = 1
Request with opcode = 0x03000100 :
01
Default PCL CFG Table Access mode configured on dev: 0
devices, ports to be used by LUA tests , and configuration files ==> {
dev=0,
port={ 0, 8, 18, 24, 20, 2 },
ledIf=0,
portCPU=63
#Serdes_Port_Lst ==> 28
LUA_CLI with examples
Entering LuaCLI took 4825.085480 msec
LUA CLI based on LUA 5.1 from www.lua.org
LUA CLI uses Mini-XML engine from www.minixml.org
LUA CLI shell ready
Start fox cli main loop
Remount writable File System
DIAG>
How do I factory reset it to boot with the IOS version "image_cbs_ros_3.5.0.26_release_cisco_signed.bin"?
Thanks & Best Regards,
Juanmi
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
No, we  dont have access to the linux environment as far as I know, maybe Cisco does. When the device is bootinh try to press return and or ESC to try to get to the recovery mode.
If can´t get here,  you may need RMA the device.
Ver la solución en mensaje original publicado
4 RESPUESTAS 4
@jmhalegre
 Every cisco device is atually use linux on the background. In order to factory reset this device, use the mode button in the front . But, if you have a problem with the device, which it seems you do, factory reset may not be enough.
 Try the factory reset but be prepared to replace the firmware and /or return the device, if you can.
https://www.youtube.com/watch?v=AElAAE06ky0
Hi Flavio,
I have pressed the Reset button for 10 seconds, but the switch does not factory reset "nothing happens", the green LED is always flashing green.
Any way to reset the computer from the Linux environment?
Thank you and best regards,
Juanmi
Hi Flavio,
The option to press Return or ESC doesn't appear, snif, snif, .....
I will have to apply for an RMA.
Thank you very much for your help,
Juanmi
