cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Configure MAC authentication in ISE and SWITCH
Electronic20
Hello Community,
They could share a configuration template to configure MAC authentication on the c9200-48p switch ports and a configuration format for the ISE for MAC authentication.
I thank you very much for the information mentioned.
5 RESPUESTAS 5
hemohemoh
you admin the ISE or SW?
you need only the config of SW?
MHM
Hi @MHM Cisco World
We would like to know how to configure both switches and ISE regarding MAC authentication.
it look steps check this video, in min22 there is how you can config SW for MAB
NOTE:- the config of SW use new model of dot1x if you use legacy please mention that I will send to you SW config
MHM
https://www.youtube.com/watch?v=PRlLDhbljIE
balaji.bandi
Look at the below Wired and wireless deployment : (configuration on the switch alone not get the function correctly, ISE also required configuration to achieve this)
https://community.cisco.com/t5/security-knowledge-base/ise-secure-wired-access-prescriptive-deployment-guide/ta-p/3641515
Video help easy :
https://www.youtube.com/watch?v=nXHK1fKfLBM
BB
