cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
6
Respuestas
How to connect an extended node with another extended in sd access
Ciro G Mele
We always connect an extended node  with a fiab but you can connect an extended with another extended in sd access ?
Thanks in advance.
Ciro Gustavo Mele
6 RESPUESTAS 6
balaji.bandi
yes that is possible daisy chain - depends on what DNAC version you using :
BB
Dnac version 2.2.3.7, the equipment being used for the 2 extended nodes is a Cisco Catalyst 3560, It is possible to carry out this configuration with the 2 Cisco devices..?
Thanks in advance.
Regards.
Ciro Gustavo Mele.
Hi BB, can you name the Cisco Live session your showed picture refers to? Kinds Andreas
Ciro G Mele
I ask you a question: can an extended node be connected against another extended, we never carry out this type of configuration, only towards a fiab, can it be done?
Thanks a lot.
Ciro Gustavo Mele.
Chain of C9K or IE Extended Nodes is supported. HOWEVER, when we added support for EX chain, 3560-CX was EOS (End of Sale), thus it's not supported to chain 3560-CX Extended Nodes. When we add feature support to SDA, we test the feature internally against a range of combinations and situations. Generally speaking the testing methodology only tests current switches, not EOS switches, I hope it's clear why this is the case: testing all legacy switches (4500, 3560, 3850, etc.) for new capabilities significantly decreases the feature velocity, and if issues are found they cannot be fixed because the EOS switch O/S is in maintenance mode. Regards, Jerome
