Cisco ir829gw IP configuration GigabitEthernet 5 Cisco iOX
Kryss
I am setting up an ir829gw and I have a linux guest shell. I currently have a vlan that is in a vrf and I would like to put the GigabitEthernet 5 port in the vlan I previously configured.
However, when I try to do that, I have the following error:
dmvpn_spoke1 (config-if) #ip address 148.196.229.1 255.255.255.240
% 148.196.229.0 overlaps with Vlan148
Do you have a solution to work around this overlaps?
Alexander Stevenson
We would need to see the subnet mask of Vlan148 as well. This topic is covered nicely in this discussion:
https://community.cisco.com/t5/switching/ip-vlan-overlapping/td-p/2014524
