IOx Application Hosting on IR1835
emory.clayton
Trying to use Local manager to deploy/manage apps on a IR1835, however after logging in, I'm not given the option to configure anything. This screenshot is from the link: https://www.cisco.com/c/en/us/td/docs/routers/access/IR1800/software/b-cisco-ir1800-scg.pdf
However after logging into my IR1835, these are the only menu options I have:
Guide I'm following:
balaji.bandi
what user you login do you have enough priv 15 for GUI access :
BB
Torbjørn
As @balaji.bandi said, this seems like an authorization issue. Can you post the output from "show run aaa" and "show run | i ip http auth" ?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
emory.clayton
The URL I am using is the first issue, its supposed to be:
https://<router_IP_address>:8443/iox/login
If I'm local to the router, its seems to load fine, however remotely I can't get the web page to load.
Still working through as to why...
emory.clayton
So what I was doing initially was logging into the router manager, not IOx.
The second issue was I was using the wrong port. The documentation states to use 8443, however this did not work for me. What did work was using 443. So the correct URL to access IOx Local Manager is:
https://<router_IP_address>:443/iox/login
