Cisco ASA 5506-X reset to factory settings (Reset button does not work)
huyan
Hi everyone,
I just bought a used Cisco ASA 5506-X  to learn CCNA Security. The seller said there is Firesource license on it.
I powered it on, I hooked up an ethernet cable to slot 2  and the other end to my laptop. My laptop got an IP 192.168.1.X. I followed the instruction, I tried to connect to 192.168.1.1/admin. However, there was a kind of time out error said the page takes too long to load.
I guessed I had to reset the firewall so I hit the reset button on the back of ASA for 5 seconds. Nothing happened.
Is there anyway I can do to access the admin panel through web browser? Or if I have to reset it, how can I reset it when the reset button does not work?
Thank you!
balaji.bandi
If the button has been disable via the "no service sw-reset-button", it won't work.
if you have console cable connect let it boot.
config t
configure factory-default
another good document with steps :
http://www.mokonamodoki.com/how-to-factory-reset-a-cisco-asa-5512-x-ips
BB
5 Replies 5
balaji.bandi
config t
BB
Hi BB, Thank you!
I just ordered a USB to RJ-45 Console cable, I will try follow steps.
I am at ciscoasa>
I type in ciscoasa>enable but it asked for password.
Since I don't have password. How can I bypass it to reset the ASA to factory default?
Thank you!
please ignore, I just found the solution here : https://community.cisco.com/t5/security-documents/asa-password-recovery/ta-p/3126046
Thank you all for help!
Just press Enter key without any password because the device doesn't come with any default password.
@huyan wrote:
I am at ciscoasa>
Thank you!
