C9115AXI-E and SoluM ESL USB gateway
nikolanikolic
could someone please, help me with the issue that I have?
I saw this document https://documentation.meraki.com/MR/Deployment_Guides/SoluM_Electronic_Shelf_Labels_(ESL)_Integration_with_MRs
But in theory is it possible to connect C9115AXI-E and SoluM ESL USB gateway?
BR, Nikola
Leo Laohoo
Nope.  The USB port is not a network port.
Thank you for your swift answer, but what do you mean by USB is not a network port?
I saw that some people connected modems
What is it used for on this type of AP?
GlennGo
Hi Nikola,
I recently came across your blog post. My name is Glenn, and I work at SOLUM. Yes it is possible.
To clarify, you’ll need a Newton Cisco USB Gateway (this is because Cisco only supports serial to USB, unlike other vendors like Meraki, which support USB to Ethernet, the "normal" Newton USB Gateway is not supported). After that, you need to plugin the Newton Cisco USB Gateway, and deploy the container application via DNAC.
If you need further assistance, feel free to reach out to our helpdesk at support@redmine.solumesl.com.
Best regards,
Glenn
