Bookmark
Subscribe
571
M12-RJ45 Adapter Multigigabit Ethernet Support Switch
gunheon103
I know that the M12-RJ45 Adapter supports Multigabit Ethernet, is there a switch that is supported? IE-3400H supports M12 code, but does not support Multigabit Ethernet.
Albert Mitchell
the IE3400H only supports speeds up to 1000Mbps.   to achieve 1000Mbps, you need the M12  x-code connector.  this has 8 pins.
the IE3400H does not support speeds above 1000Mbps.  for instance 2.5Gbps is not supported.
Albert Mitchell
Thank you.
